cam help
Old 08-16-2010, 12:55 AM
GraphicNature's Avatar
Default cam help
here is the deal im about to install a ms4 cam in my buddies car and i want to still be quicker, so i am looking at upgrading my cam.
i have a 99 ta stock heads, tsp 228r cam with all supporting mods, longtubes with full exhaust, ls6 intake, a4 with 3600 stall but i am thinking about swapping to a th350 with 4000 converter and 3.23 gear (have not changed since i may go with the th350) and the car with be on a 150 hit. but i want a max effort cam it is not my dd by any means its just a race car.
the cams i have come up with are:
trex 242/248 608/612 110
vindicator 240/244 605/596 112
tr raptr 236/242 615/615 111
esp 236/248 615/615 110
Old 08-16-2010, 02:43 AM
itsslow98's Avatar
bigger isnt always better, id drive it the way it is until you get all of its potential out. Just my .02.
Old 08-16-2010, 02:48 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
All those cams are good candidates. If you really care though you will go with a custom spec for your type of gearing/stall you are going to run with.
Old 08-16-2010, 06:44 PM
george g's Avatar
I'ld put a little more gear in the rear.
Old 08-17-2010, 12:51 AM
i have not because i may put a 350 turbo in the car, i said it is not my dd but i do drive the car. and i have the 228r cam already sold was never that impressed with the cam so i want a bigger one.
Old 08-17-2010, 06:37 PM
i have also found a set of stock ls2 heads off a gto would they be worth upgrading to
Old 08-17-2010, 06:45 PM
98z8uup's Avatar
I say custom. Also look into getting a set of heads.
Old 08-17-2010, 07:09 PM
2002silverz28matt's Avatar
change the gears in the rear to a 373 or 390. if ur going to a th350 with that kind of cam, there is no point in gearing the car for the highway, its not gunna be somethin to take on a road trip. plus a 4000 stall with those high gears wont be much better on the highway than the low gears b/c anytime u go up a hill ur gunna be turning 3000+ rpm's, no lockup. or put in a level 2 4l60 if u dont want it to be a race car, cant have both. its really not that bad cruising at 55 on short trips, i have a th400 5200 stall 390 gears and drive it to work everyday!
Old 08-18-2010, 12:54 AM
i might go to a 3.73 gear or keep the a4 and go 4.10. i am not to worried about keeping it a trip car i have other cars i can carry but i am still going to drive the car to the track some and out to eat also an do some street racing with the car.
i have found some pull off ls2 heads off a gto how much would those heads pick me up and no they are not ported
Old 08-18-2010, 01:28 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Those heads would probably be comparable to a set of stock 243's +/- a couple rwhp/rwtq. Depends on the application its going on with the cam its going to be paired with.
