comp 2010 master lobes
look at top of page 18... ( http://www.compcams.com/information/...obesection.pdf ) Then lsk lobes listed on sites where you can make your own custom cam have the wrong lifts advertised? Is this a misprint? or do i have the wrong pdf?
The lsk lobe chart shows the lift with 1.7s no math needs to b done. The lifts they show r way bigger then what the sponsors list on the sites. Am I making sense? The lifts u provided r listed as the 1.6 lifts on the chart. These r what the sponsors list and its wrong. Unless the pdf is wrong. We all know it makes no sense to list a 1.6 lift rating when all ls1s come with 1.7 or better. Basically what I'm getting at is look at the 1.7 lift column those numbers r what people will end up with if this is true info.
LS1Tech Premium Sponsor
They list the different ratios for all the lobes, not just what came on the LS1's (1.7). This is because other platforms sometimes use "LS1" lobes on their cores and see what they do. Some sponsors on this forum and other LSx forums use lobes that were not built for LSx engines and sell alot of them. In many cases, they've done the R&D on this and it works great, but in other cases it can be VERY hard on the valvetrain and cause instability and ultimately broken parts.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Yea, I saw that. For the amount of data that was compiled for a catalog of that size, I can imagine it'd be next to impossible to get them all correct! Over-all though, they do a great job on it each year, and it's as easy as multiplying the lobe lift by your rocker ratio to get your valve lift anyway
__________________
