Need help
Old 08-16-2010, 08:43 PM
z28master's Avatar
Default Need help
Just bought a nitrous kit for 95 z28 followed instructions step by step have stock motor so i just put 100shot setup (jets) and when i flip the switch it does activate just enough to waste my juice but absolutly no power gains. what have i done wrong or didnt do at all? BY THE WAY I HAVE SHOT A 10LB BOTTLE WORTH SINCE HOOKUP JUST TRYING TO FIX IT
Old 08-16-2010, 08:45 PM
z28master's Avatar
By the way before anyone gets excited about my username lol it is only thing i could think of that was not already taken and that i could remember, guess i need to change now
Old 08-16-2010, 08:46 PM
Nomind's Avatar
Don't suppose that you could shoot a quick picture of how you have the nozzles in the intake?
Old 08-16-2010, 08:51 PM
RamAir95TA's Avatar
What else have you installed (individual components)? You're leaving your problem very open-ended.
Old 08-16-2010, 08:52 PM
z28master's Avatar
Cant at the minute, not with the car i had the port running into the cold air and thought that was my problem so i bought a plate and still the same i could post one tomorrow. Thanks for fast reply
Old 08-16-2010, 08:55 PM
z28master's Avatar
Just standard hookup instead of hooking up switch under gas pedal hooked up at throttle?
Old 08-16-2010, 08:57 PM
z28master's Avatar
Nomind i meant i cant post one at the minute im at in-laws house car is at home
Old 08-16-2010, 10:50 PM
Nomind's Avatar
I would be concerned about where the N2O is going, if you don't feel anything when you activate it, and you've used a whole bottle. Sounds like it's venting into the atmo, somewhere.
Old 08-16-2010, 10:58 PM
keeven1320's Avatar
u need to check the fuel side, n2o wont make power with out fuel, try flowing just the fuel side of it in to a bucket or something
Old 08-17-2010, 12:31 AM
z28master's Avatar
Default thanks again for all the help will definatly give it a deeper look
Thanks again for all the help I will definatly look a little deeper tomorrow an find out what's goin on
Old 08-17-2010, 02:35 AM
brucer's Avatar
i have always checked the fuel side first, actually dont even worry about the nitrous solenoid until i know for certain the fuel side is working first..
