Idle adjustment
Old 08-16-2010, 08:47 PM
jazenz28's Avatar
Default Idle adjustment
Can the idle be adjusted on a 99 z28?
Old 08-16-2010, 08:50 PM
eseibel67's Avatar
Manually, no. But custom tuning can put it anywhere you want it.
Why are you asking?
Old 08-17-2010, 07:12 PM
jazenz28's Avatar
Upgraded alternator (200 amp with smaller pulley) for sound system. At idle and in gear, voltage is under 12 and lights dim a little.Raise RPM slightly and voltage stays where it should.
Old 08-17-2010, 11:14 PM
eseibel67's Avatar
Dim lights is what you get with an underdrive pulley at idle. Alternator is spinning too slowly.
Old 08-18-2010, 01:12 PM
jazenz28's Avatar
A smaller pulley on the alternator makes it spin faster.
