Windage tray
Old 08-16-2010, 09:34 PM
Money1's Avatar
Default Windage tray
If I convert A LT1 Main caps from a 2 bolt to a 4 bolt
can I use the stock windage tray.
Old 08-16-2010, 11:14 PM
WS Sick's Avatar
ya, but you'll be relegated to using the stock main bolts, unless you use studs for a windage tray, But the stock windage tray is not the best around, if youre spinning money I would go with a better offering.
Old 08-17-2010, 08:31 PM
97Z28SS's Avatar
Milodon makes some very good ones.
Old 08-18-2010, 01:55 AM
BALLSS's Avatar
yes
either reuse the OEM 3 long studs or buy a set of Miloden studs
use 1/8" spacer washers betweenstud & windage tray to clear the rods on the 383
Quick Reply: Windage tray
