Creaky noises normal with poly bushings?
Ever since I installed BMRs front and rear swaybar kit with poly bushings, I get a creaking sound at low speeds from the rear. It doesn't bother me, I'm just wondering if it is normal. I only used the silcone grease on the bushings that go AROUND the swaybars, but none on the end links. It's also been about 10 degrees here everyday, so maybe that had something to do with it...
Anyways, it handles incredibly now, so I can certainly live with it if it is normal.
Tommy
Tommy
