Trying to quiet down my exhaust...
Trying to figure out what I should do...my current setup is...
LT's
TSP Catted Y
SLP LM1
...I first thought about just swapping out the LM1 resonator and making it a "Borlamouth", but I realized the Borla has a 5'' diameter and I don't want to deal with scraping problems (my LM1 resonator occasionally scrapes on speed bumps and it has a 4'' diameter).
Before the cam swap, I didn't mind how my exhaust setup sounded, but now, it's a lot louder at idle and it has a lot of rasp around 2000 rpms, which drives me crazy. My next idea was just to put a stock catback on and get a cutout. My friend ended up having a stock catback sitting in his garage, but it has a Flowmaster muffler welded in place of the stock muffler. Would that be a good option for me? I'd have a cutout if I went that route, so losing power through the Flowmaster wouldn't bother me. I'm basically looking for an exhaust setup that will be quieter at idle and have no rasp. Thanks for the help.
LT's
TSP Catted Y
SLP LM1
I converted my LM1 to a magnamouth yesterday. Had LTs and ORY with the lm1 catback as well as a ls6 cam, but that didn't really affect the sound. Thanks to a 240 dollar ticket for a "muffler violation" I figured I could try replacing the lm1 "resonator" with a magnaflow muffler. I did and it did quiet it down some but imo not that much. It is still very loud. It did clean up the sound alot. It is loud AND sounds good, which could not be said about the lm1 imo. The rasp is still there from like 2100-2300 ish but not near as much as the lm1. WOT still sounds exactly the same to me.
Got a similar issue. Got Pacesetter Headers, off road y-pipe, and LM1. The drone at 2200-2600RPM can give you a headache after an hour of highway cruising. I threw some Dynamat and DynaPad down but it really didn't help too much with the exhaust, but the speakers sound outstanding.
My next step is to turn the LM1 into the SLP PowerFlo exhaust. I heard that was supposed to quiet the LM1's down a bit. Anyone done this mod? Did it help any?
LT's
TSP Catted Y
SLP LM1
LT's
TSP Catted Y
SLP LM1
i have the same setup only wit borla, and mine is quiet down low, not to get off topic but does ur ypipe have ground clearance issues?
i had LT, ORY, and LM1. I added powerflo mufflers and a single cat in the I pipe it's a lot quieter. I can feel a power lose but i think that is due to the cat witch i only put in for inspection purposes. i will prob be switching back to a ORY
