Valve springs to go with?
LS1Tech Premium Sponsor
For a beehive spring I'd go with the PAC 1518's, or for a dual I'd say the PRC .650" lift spring kit.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Thanks guys! What are your thoughts about doing a high pressure/volume oil pump during the cam swap? My car just hit 30K and I've got plenty of oil pumping from what the tac reads...lol So much to where my friends have questioned if it was too high. I kinda thought I would be ok because of the low miles and because I'm not doing heads. I am putting on a FAST 90 during the swap.
Internet Mechanic
On my VRx4 cam its 228/230 and .58x/.58x lift or so and ran the newer Comp Cam 918's Never an issue.
BUT after now going on 3 years and maybe 8k, as a matter of matience I will be swapping them out for either a dual or another beehive, (probably Pac) and I wanted to see how much pressure has degraded.
You should hear it when we do Spintron testing! There is no combustion, at all, happening...yet it can be VERY loud from just the sounds of the valvetrain (and a bit from the machine of course)!
__________________
