NT05 vs NT05R vs BFG DR
Getting ready to pick up some R17 315s before winter kicks in, and I'm debating between these three. The last set of Nittos I had, 555Rs, I really didn't like, because they were skinny for their size, didn't really hook that well, and had a very short life (primarily because of the tread cracking). I ran a set of BFG DRs right afterwards, and liked them quite a bit more (better traction on dry pavement, in the rain, and even the snow [I know]), not skinny for their size, and they lasted a decently long time for DRs.
Sorta up in the air between these three in 315s, though. Are the Nittos in that size still skinny compared to other tires, especially the BFGs, of the same size?
Well, Nitto lists the specs of their tread widths right on their website.
315 NT05 is a 12.4 inch width on a 17x11
315 NT05R is a 12.48 inch width on a 17x11
We just picked up a set of NT05s for my girlfriends camaro, because they look like they are a decent compromise between a street tire and a drag radial. They are relatively soft, and light for what it's worth. Sitting in my garage waiting for the wheels to get here today from OEwheels
Are you looking for a dedicated drag radial, or an in-between like an NT05? Also, 13k miles out of my NT555Rs before my left tire picked up a bolt Still had another 3-5k miles to go on them before they were shot. Easily had 10 or so John Force burn outs too at the track.
A dedicated drag radial would work, since I don't drive the car a whole lot, but I'm not against going with a dual-purpose tire, either. The BFG seemed like a good all-around tire, since it stuck pretty good, but highway and street manners weren't bad, and they did fine in the rain (had them on the car when it was still a daily).
I wouldn't have any problem running the BFGs again, but I don't have the spare money to pick up the BFGs and a set of the Nittos to try out. I'm just worried that, if I do go with the NT05 or NT05Rs, I'll have the same problems that I did with my 555Rs. The BFGs are listed as 12.4", so at least I won't have to worry about the new Nittos being as skinny as my old ones.
If the specific problem you had with Nittos in the past was tread cracking, I would go with intuition and say you just got your hands on a bad set of tires :/
My NT555Rs didn't have that problem, and my NT555s don't have that problem either. Arizona sees 115 degree days regularly in the summer, and consider that asphalt is many many degrees hotter than that at times. You are talking about this kind of cracking right?
In the end, there is nothing wrong going with what you know, and if you had good experiences with BFGs, nothing wrong with going for it again If you don't drive the car a whole lot, the BFGs are probably stickier than the NT05. As far as the NT05r, well, just give those a search in this section as well... Not much in the way of tread life, and hook decently.
I wish I could offer more opinion on the NT05s as we have yet to try them out, but there are a fair amount of good things to be said if you search "NT05" in the wheels & tires section specifically.
I may give the NT05Rs a spin, just to see what they're like. Mileage isn't a huge issue since I probably won't be putting 2000 miles a year on the car.
If you like the BFG's, its hard to recommend changing something thats working well for you. These are excellent tires indeed. The new NT05R may be a fun tire to try but I haven't seen any tests head to head with the BFG. Treadware rating wise the NT05R actually has a higher (200 vs 100) rating than the 555R which usually means slightly less grip but longer life. This however can come down to the driver, the vehicle and the track. Let us know if we can help you with your tires either way. We'd love to earn your business.
The cracking I got was actually completely different, heh...was a series of cracks 2" to 5" long, about 1/16" to 3/32" wide, across the tread blocks. I guess I can't complain too much, as Nitto does warn against using them in the cold, and I didn't have a choice (only car and outside parking). Maybe because it was a 245, but I just couldn't hook up with them, even when it was warm out. :\
I don't think you will be disappointed with the NT05s
No worries on earning my business - I've been buying tires from you guys for years now.
I had the NT05's in a 275 on my old TA. Loved em. I'm running a 315 Toyo Proxes TQ drag radial right now and LOVE them. You should consider them. They are nice and sticky. I decided to go with them over the NT05R because it's my DD and even though I only drive 1 mile to work and that's about it (Except the weekends when I go out on the street). I think the Toyo would have been better in case I ever run into rain.
I'm not a "Won't drive the car in the rain" guy (it's a car, after all), but I try to avoid it now that I have a daily beater, so wet traction isn't a huge issue for me.
I love my NT05s but they do not hook as well as my BFG DRs. I got the NT05s for all around performance (including road coarse) and are the best tire I have had for that so far.
Are those 17" tires? Looked on Tire Rack and didn't see them listed under 315 35 R17s. Is the Toyo any stickier than the Nitto, since you've run them both?
The Toyos are nicely priced too
1 Post
I have near 15K on my NT555s and don't think I've gotten half life out of the yet (no 'smoke shows' or burnouts on my street tires). I had 1 start to rot and goose-egg on me so I replaced it w/an NT05 (got it NEW for 100) and have no issues w/any of them yet. Will get a mate for it shortly, but it was a 2-day delivered and on the car deal.
