the problem is back
the problem is back
so after replacing the coil it ran good. but now the problem is back.
ill be driving an the car will just shut off an turn back on
i have no idea at this point. i have a new dynaspark coil wires an plugs. what should i do?
ok ill try that. this just pisses me off cuz all i do i baby this car an she does this to me lol. an i checked the harness when it first started to this an it was fine, so ikd i was about to buy a t350 an stall an lt's but i cant cuz of this
i checked the icm an i even spaced it away from the head. today im putting the car in the air to look at all the grounds. i neeed to find the problem imports vs. domestics is comming up i need to be fast.
I had a similar problem but mine turned out to ignition wire blowing out and countless ignitions switches. To this day I have yet to figure it out. Check on your fusible link and connections for the ignition wire.
