Need help with 91 K1500
picked this up real cheap because the trans wont come out of 2nd. The truck starts and idles great, and i have 1-2 and reverse. The truck is a 91 K1500 with a 700r4 I believe. If anybodys got any tips or tricks, i would sure appreciate it.
Check the fluid first.
Had the same problem in my dad's chevelle after rebuilding the tranny. Turns out we did everything right, but the valve body was bad.
Valve body is on the bottom of the tranny so you may be able to do it without dropping the transmission.
This is a 4l60e, but same concept
http://www.youtube.com/watch?v=6Svl0fDl1qI
Just did some reading, could also be a governor problem or TV
http://www.gottransmissions.com/blog...0r4-shift-gear
Fluids full, red. Previous owner said he changed the filter and fluid when it happened, didnt fix the problem so he parked it. Nobody has bothered to check for any easy fixes, and I have no experience with this truck so it very well could be something minor. Although it does have 164k on the clock and i hear these 700r4s are not very choice trannys.
