396ci LT1 Convertible Race Car Build
Old 08-19-2010, 10:43 AM
94Z28rag's Avatar
Thumbs up 396ci LT1 Convertible Race Car Build
1994 Z28 convertible, TH400 w/ transbrake, 9" rear, 275 M/T ET Street Radials
This was my first car, I've had it for over 10 years. It had 117k on it when I bought it, and it's at 160k now. I've been drag racing (Jr. Drag Racing back then) since I was 8 years old. My dad and I have been working on making this a race car for about two and a half years.
So here's where we are now:
  • New convertible top
Rear end, rear suspension:
  • Quick Performance 9" rear, 35 spline Moser axles with 4.56 gears and a spool
  • UMI Chrome Moly Adj. Torque Arm
  • UMI Double Adj. Rod-ended Panhard Bar
  • UMI Double Adj. Rod-ended Lower Control Arms and relocation brackets
  • UMI convertible subframe connectors
  • Solid Wolfe drag race swaybar welded on
  • Custom built 3" steel driveshaft
  • Comp. Engineering 3-way adj shocks
Front end, front suspension:
  • UMI Tubular K-Member
  • UMI Tubular Lower A-Arm Set
  • UMI Tubular Adjustable Upper A-Arm Set
  • QA1-R Adjustable Front Shocks
  • QA1 275 lb. Front Springs
  • Poly motor mounts
  • Madman manual steering rack
  • Madman alternator relocation bracket
  • DMH Fabrication Chrome Moly steering column
Interior, safety:
  • Wolfe 6-point converted to a 12-point full roll cage
  • Kirkey Pro Drag seat
  • Impact 6-point harness
  • Grant Formula GT steering wheel w/ SFI quick release
  • Moroso sealed battery box in trunk w/ cutoff
  • Painless 8-rocker switch panel and Painless chassis wiring harness
Transmission:
  • Transmission Specialties TH400, RMVB, transbrake
  • Trans cooler
  • Pat's Performance Converters Billet 8" converter, mechanical diode, 5400 stall
The engine:
  • Davis Race Engines built 396ci LT1, roughly 12.6:1 compression, 93 octane
  • Forged crank
  • Forged H-beam rods
  • Forged Diamond pistons
  • Custom Advanced Induction top end
  • Advanced Induction 200cc GM LT1 heads
  • Advanced Induction Hydraulic Roller 25X/26X on a 106*, .6XX lift
  • Advanced Induction ported LT1 intake manifold
  • Racetronix 63 lb. flow-matched injectors
  • AS&M monoblade throttle body
  • LPP 1 3/4" to 1 7/8" stepped stainless steel longtubes
  • Dual electric cutouts immediately after collectors, Y-pipe into Hooker catback
A big THANK YOU shout out to Snyder Fabrication (http://snyder-fab.com/) for all of his hard work with the roll cage and just about every other custom piece on this car. Also, Davis Race Engines for their tireless work in the spec'ing, machining, and assembling of this first class 396ci LT1 engine.
Pics:
Painting the cage
Front suspension pieces
The car and TBSS tow vehicle in the background
This is just some of the extra wiring I removed from the engine bay (replaced all OEM chassis wiring with a Painless harness later on)
Engine and transmission on the K-member ready for install
Ready to roll under the car
View from above the engine bay
View from the front after install
Another front view
94Z28rag's Avatar
Thumbs up New Pics!
Time for a few more pictures! Almost time to start her up and head to the strip! Dash is almost complete, waiting to finish up a little more wiring before securing it completely. The Painless wiring harness has completely replaced the OEM chassis harness.
Interior coming together
All new brakes and front end
The holding tank for parts...
Another round of parts are in - Madman travel limiters, save your *** bars, TH400 dipstick, B&M trans cooler, etc
M/T 275 ET Streets, S/R Radials, and Billet Specialties Street Lites - THESE WHEELS ARE STUNNING IN PERSON
Tach and shift light mounted, dash and OEM gauges are in
94Z28rag's Avatar
*Reserved again*
Old 08-19-2010, 10:54 AM
robsquikz28's Avatar
lol looking good buddy, reserved huh? more pics
Old 08-19-2010, 10:55 AM
94Z28rag's Avatar
Lots more to come. I just didn't want to take any chances of filling up the OP.
Old 08-19-2010, 12:43 PM
BOLO's Avatar
Very nice looking project
Old 08-19-2010, 03:22 PM
InsaneAuto86's Avatar
Nice! any plans to mini-tub?
Old 08-19-2010, 03:26 PM
94Z28rag's Avatar
No. No need at all. I'm only running a 275 tire. Plenty of clearance. I've had 17x11s with 325's on there without an issue in the past.
Old 08-19-2010, 04:14 PM
AChotrod's Avatar
Looking good!!
Old 08-19-2010, 04:29 PM
White.Lightning's Avatar
Where in West Chester are you from? Maybe I could stop by once the car is running. Sounds like a fun ride!
Old 08-19-2010, 08:24 PM
flyinZ's Avatar
Lookin' good, keep it up!
Old 08-19-2010, 08:55 PM
fuel's Avatar
......dont forget to paint your engine bay......
it might set you back a couple of weeks and mabe 400 bucks or so.but youll be happy you did
looks good keep it up
Old 08-20-2010, 08:05 AM
94Z28rag's Avatar
Thanks for the compliments, guys.
Just south of South Campus.
The engine bay is actually in great shape paint-wise. I spent a few hours soaking with Simple Green and scrubbing away and it turned out damn good. Other than some rust cleaning/painting that needs to be done in the OEM battery area, I don't think I'll be doing much. I'll take some pics of how it looks when it's all cleaned up.
Old 08-20-2010, 08:07 AM
Originally Posted by 94Z28rag
Just south of South Campus. About 1/4 mi from the football stadium.
Let me know when it gets running. I'll swing by to check it out
Old 08-22-2010, 11:06 PM
94Z28rag's Avatar
Sounds good.
Old 08-23-2010, 12:55 AM
DMH Fabrication's Avatar
Looking good so far!
Old 08-26-2010, 03:52 PM
94Z28rag's Avatar
Thanks! I'll take some more pics once your column is set up in the car with the Grant wheel
Old 08-26-2010, 03:59 PM
RamAir95TA's Avatar
I'm surprised no one noticed the Model A with the LS1/GTO motor.
Old 08-26-2010, 05:03 PM
94Z28rag's Avatar
Me too!
Old 08-26-2010, 07:24 PM
SoxXpupPeT's Avatar
Awesome build! i love the way vert cars look with the rollcage like that
Quick Reply: 396ci LT1 Convertible Race Car Build
