Will these Wheels fit...
Old 08-19-2010, 12:53 PM
95ZR28's Avatar
Default Will these Wheels fit...
My stock suspension 95 camaro? I dont want them to stick out from under the side of the fenders and look like some dam hooptie!
http://www.oewheelsllc.com/Wheels-fo...-p6902230.html
Also what tire size could I get by with on these rims with out rubbing any where?
Old 08-19-2010, 12:55 PM
meine96ws6's Avatar
they will fit fine.. and realistically speaking you don't need anything over a 295 rear..and the max i would run up front is a 275..
Old 08-19-2010, 01:13 PM
95ZR28's Avatar
What about the series? 255-45-17 up front and 295-45-18 rear?
Old 08-19-2010, 01:38 PM
djjab57's Avatar
I would keep the rear at a 40 , are you on lowering springs ?
Old 08-19-2010, 02:00 PM
95ZR28's Avatar
No stock springs. So 45 up front and 40 in the rear?
Old 08-19-2010, 02:06 PM
egott_91's Avatar
40 up front and 35 in the rear is what I'd run if I had staggard fit like that.
I just got 18's all around and I'll be running 275/35-18 up front and 295/35-18 in the rear. W/ the 17's i'd go 275/40-17 then 295/35-18. If you don't mind hammering your inner fenders, 315's always look good, but you said w/out rubbing, so 295 is your best bet.
Old 08-19-2010, 02:10 PM
95ZR28's Avatar
Do you think it would be better to run one size rim all the way around or is it just my prefrence? Do alot of people run the stag off set?
Old 08-19-2010, 02:14 PM
egott_91's Avatar
Your preference if you like the same size wheels all the way around or not. I have a wider wheel in the back, so mine is technically staggered, but it's not two different size wheels. It's your decision and there are quite a few ppl that run the 17/18 combo. If you go same size wheel all the way around (say a 18X9.5) then you could get the same size tires all the way around and then you'd be able to rotate the wheels for extended tire life. A wider tire in the rear always looks meaner though, but it's all in your preference.
Old 08-19-2010, 02:21 PM
95ZR28's Avatar
Thanks, I like the wider tire my self. I just have some money to spend and Im going to start building a new motor and put some wheels on it.
I also have some LS1 factory GM injectors I need to sale they are 28# that ill ship for $60 with insurance. And Phantom tach with shift light with blue lense and cover installed. That is never used that ill sale for $135 shipped with insurance. So if yall know anyone interested or yall PM me.
Old 08-19-2010, 02:34 PM
egott_91's Avatar
If you want the same size wheel (say 18's) and it's not offered as a package on OEWheels website, email Scott at "Scott@oewheels.net" and he'll be able to help you out...great guy to deal with! Or give him a call.
Old 08-19-2010, 02:37 PM
95ZR28's Avatar
Thanks man I will do that!
Old 08-19-2010, 02:43 PM
djjab57's Avatar
I have the z06 wheels same size as those, I run 40 up front and 35 in the rear. I put 45 to see how they fit and thats why i say 40 out back max
Old 08-19-2010, 03:01 PM
95ZR28's Avatar
Sweet man that helps alot. Thanks
Old 08-19-2010, 04:57 PM
tricked94camaro's Avatar
i wouldnt even trust those cheap rims to begin with
Old 08-19-2010, 06:29 PM
brokenbird's Avatar
well you must not have had a set from them they are very nice and i could not be happier with mine fit and finish wise unless you go spend 3k on a set of wheels just get ahold of scott he will hook you up i love my DD C6Z in 18/8.5 and 18/10.5
Old 08-19-2010, 08:41 PM
95sscamaro's Avatar
I have the same size on my car, the 40 will rub on hard turns and big bumps, go 275/40/17 285-295/30-35/18.
P.S. if you lift the car with a lift the wheels wont fit they will hit the bump stop, I just cut mine out and they fit fine.
Old 08-19-2010, 11:02 PM
meine96ws6's Avatar
I am running a staggered set ...i love the look of the 17/18 combo and the bigger tires out back..
Old 08-19-2010, 11:20 PM
slomarao's Avatar
I run a 17/18 Zo6 rim
265/40/17 fronts 8.5 inch wide
295/35/18 rears 10.5 wide
Had to grind out the wheel wells to fit properly in the rear.
Old 08-20-2010, 08:49 AM
egott_91's Avatar
What's wrong w/ OEWheels? Apparently you haven't read the NUMEROUS amount of threads that are commenting on how much they LOVE their wheels from OEWheels and how they couldn't be happier w/ them.
Sure, it would be GREAT to have an expensive set of wheels, but then you're CONSTANTLY worried about something happening to your $2,000+ dollar WHEELS....and for the money, these wheels are awesome. I just got a set of C5 DD w/ the machined face and black vents, they're going on tonight. Yeah, they aren't $1,000 per wheel, but who cares, they look good and they're built well!
Old 08-21-2010, 01:23 AM
Wyocattech's Avatar
Im runnning black c6 17-9" wheels on my Trans am. Love them!! Except my car was one of few with the large axle flanges. Best money ever spent on my car!!
Quick Reply: Will these Wheels fit...
