engagment issues
engagment issues
ok so I just did the clutch test, whereas you sit on a flat spot, engage the clutch, put the tranny in 1st gear, slowly rev the engine and see if the car moves. well, at about 5000rpms the car starts to move forward. Damn It! so the clutch is a SPEC 3. its got some time in the car but since i rarely drive it, it might have. I bought the clutch in 2005. since then ive put maybe 3000 miles on it. well when i put the clutch in, I knew little about the details on clutch installation. I had the stock flywheel turned and used it with my SPEC clutch kit. in the package cam a round metal thingy... at the time i didnt know it was a shim....still have it today. anyways i stuck the kit in the car... clutch didnt shutter or shake , seemed to shift fine. so i figured everything was cool. fast forward to today. Ive been thinking alot about proper set ups and the short cuts I may have taken along the way. Its a learning process. so thats what lead me to checking the release of the clutch. so after that exhausting story, my question is... is it too late for this clutch? can the shim stim be used to correct the problem. what are my options?
Thanks in advance
Shawn
Thanks in advance
Shawn
i didnt use a shim with my spec 3+ but heres a thread 4 u to look at
https://ls1tech.com/forums/manual-tr...need-shim.html
its most deff that the next clutch going in i will measure, i guess what my question is; is it too late to shim it or am i needing a new clutch or an adj master? from what i am reading, there is less air gap once its broken in, so is it too late to even consider r&r the tranny to put the given shim in?
The kit is designed to use the shim...if it wasn't installed then you will be more likely to have release issues. Also, do you know how much material was removed from the flywheel during the resurface? Either way you can reference the shim link above to check measurments.
Ultimately you will need to install the shim and please don't hesitate to contact me with any questions you have. Thanks!
