High RPM Miss Continues! Valve Float??
UPDATED!!!
OK so I have been having High Rpm issues with my car now for about 6 months
I thought it may be fuel so I replaced
Regulator
Fuel Filter
255 Fuel Pump
42lb injectors
Put it on the dyno and the fuel was not an issue and like usual it stared missing at 5800 rpms ...Hp and Torque fall off exactly the same
fuel stayed in the mid 12s...
So i bought a Dynaspark opti and checked all the measurements before I put it on (dowel pin and all)
New MSD coil
New Taylor Wires
tried 2 different Icms
Added and checked grounds
ICM cooling Mod done
NGK TR6 plugs (gapped at .39)
MSD Digital 6 box (does it with or without it)
New Patriot Valve Springs shimmed between 1.780 - 1.800
Push rod length looks great
1/4 turn past zero lash on valve adjustment
Compression check showed good
Car still misses at 5800 rpms but will pull until the shift light at 6400...
Once it starts missing the check engine light now comes on and the car don't want to idle.. Turn the car off and back on and the light is gone and it idles fine...
Car went 11.9 @ 112 shifting at 5700 so in know the motor is strong just need to figure this high rpm miss out!!
Could this be an Harness or PCM problem??? What about a Cam issue??? I am at the end of the road with this damn car...
Regulator
Fuel Filter
255 Fuel Pump
42lb injectors
New MSD coil
New Taylor Wires
I am going to asap..I am waiting for them to email me the file...
Or I may be able to scan my paper copy an post it
it looks a lot like the dyno sheet you posted in an old thread where you were showing valve float...hp and tq fall off at 5800 the exact same and a/f stayed pretty good...
Matt
Matt
I would have said opti all the way since that is what mine did, but I see that you swapped it out. A cheap solution would be to run a set of 918 beehives and see what happens. The 918's will easily handle that cam. Whatever pressure those springs put out is only part of the equation. They might be too heavy for your application and aren't designed for high rpm use.
Yea I was blaming the opti for the longest time too...but after all the optis and now a brand new Dynaspark I am ruling it out..as well as the coil and ICM plugs wires and anything Fuel related...I have been through all of it multiple times with several different parts...
The car never regains power once it starts to miss...even if you stay on the gas it just sputters and hits a wall...
I don't want to run Dual springs so beehives are prob what I will go with... are the 918s good?? up for opinions...
Thanks everyone!
Thanks everyone!
Its a TEA CNC heads cam package that was done back in 2002... so they have been run pretty much since then...the car has sat some but seen a lot of track and street use and lots of 150-200 shots...
The springs are what TEA installed originally so I assume that they were capable of the RPM then but they are 8 years old...
I don't want to run Dual springs anymore so beehives are prob what I will go with... are the 918s good?? up for opinions...
Thanks everyone!
Thanks everyone!
http://www.compcams.com/Cam_Specs/Ca...csid=1112&sb=0
They are pretty cheap too if you shop around:
springs for $187.95 http://www.summitracing.com/parts/CCA-26918-16/
retainers for $26.95 http://www.summitracing.com/parts/CCA-787-8/
locks $22.95 http://www.summitracing.com/parts/CCA-648-16/
Maybe one of the vendors in here could get you a package for $200ish?
I run the 918's on my car. My cam is the XFI 468, 242/248 with .584/.579 lift. I shift at 68-6900rpm, smooth as silk. They are the recommended spring for the cam I run. I'm sure they will handle your cam quite easily. Here's the cam "kit" right from comp:
i am still working on getting the dyno posted...
Besides the obvious that the springs are old and need to be changed...Does the symptoms I described sounds like valve float would be the culprit?
Thanks joelster for the info! I will be ordering the above this week for my car..
I know I don't know what I was thinking...I just had the motor out of the car and I know i should of changed them I guess I just assumed they were ok..
Ok cool Well I will get those springs ordered...I am going to see if I can order them through one of the sponsors no here...
Thank god I haven't had one slap a piston yet... I am pulling the car down tonight because I don't want to push my luck..
Thanks everyone for taking time to post!
Thanks joelster for all the info!
Matt
Matt
Yep it very well could be valve float. It looks like float or spark scattering, but you already addressed the spark issue. Your air/fuel is pretty conservative too. It starts off around 13.1-1 then it gets richer and richer. Around 5800rpm it's just above 12-1 which is pretty conservative.
Yea we quit making pulls and tuning on it because of the high rpm issue...
It has a new Dynaspark (all specs measured and good), MSD Coil, ICM (cooling mod done), Plugs .39 gapped TR6s, Taylor Wires, checked all grounds, checked wires in harness, with or without Digital 6 box does it
Fuel wise...New lines, Regulator, 42lb injectors, 255 pump.....
so I am def leaning towards valve train...
