Nitrous Oxide - Nitrous kit
Gilchrist92
08-22-2010, 02:08 PM
Hey guys, I'm pretty set on buying this nitrous kit from nitrous outlet after doing a good amount of research on here http://nitrousoutlet.com/catalog/product.asp?category=14§ion=37&group=623&product=3204 . What else you guys would reconmend for a clean, safe, done right install, that is still on the budget side of things. I know I will need a purge, fuel pressure safety switch, and window switch. I am wondering what ones will work best with this kit and if there is anything else you guys think I should purchase. Thanks!
Greekey
08-22-2010, 03:17 PM
Have some timing pulled. New plugs.
YURVIEW
08-22-2010, 04:41 PM
I like this accessory package from Harris Speed Works, it has everything you'll need except a Timing Retard device. (but you could do the Timing Trick for free if you are spraying 100 or less). the MicroEdge controller has everything from window switch to air/fuel Ratio lean cutoff.
http://www.harrisspeedworks.com/product.php?productid=12&cat=6&page=1
Nitrous outlet has a couple of accessory packages as well. I love the bottle mount/heater, but the packages aren't as complete as the HSW packages..... I believe Nitrous outlet now offers a device similar to the HSW MicroEDGE, with similar features.
http://nitrousoutlet.com/catalog/categories.asp?category=23§ion=121
dnkynrbk
08-22-2010, 06:30 PM
Just give Chris a call @NitrousOutlet tom. they will get you fixed up.
I would get a progressive controller and you dont need a lean safety switch.
Nitro Dave's Nitrous Outlet
08-23-2010, 10:40 AM
We offer a Brand X complete package that has the system you are looking for.
Here is a link to it.
http://nitrousoutlet.com/catalog/product.asp?category=33§ion=159&group=778&product=3610
Shoot me a pm or give us a call and we can go over your combo and tell you what all you may need.
Thanks
Dave
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
