can i reuse the cam retainer plate
Old 08-22-2010, 04:51 PM
slap(A)hoe's Avatar
Default can i reuse the cam retainer plate
i am doing a cam swap in my camaro can i reuse the cam retainer plate from the factory or do i need to buy a new one ??
Old 08-22-2010, 04:53 PM
jsteele90's Avatar
just reuse it
Old 08-22-2010, 04:54 PM
Trunion King
bene's Avatar
I'm reusing mine, I don't see why not. By the looks of it, it doesn't get any wear, not that much anyway.
Old 08-22-2010, 05:01 PM
samb0ness's Avatar
yes, you can reuse it.
Old 08-22-2010, 05:16 PM
slap(A)hoe's Avatar
ok thank u guys
Old 08-22-2010, 05:29 PM
ShortChevy's Avatar
Make sure you clean and locktite those bolts
Old 08-22-2010, 06:49 PM
vettenuts's Avatar
On the back side of the plate there is a seal against the block. Check the seal for cracks or tears. Don't re-use unless the seal is in good condition.
Old 08-23-2010, 09:31 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
THIS!!
A broken, cracked, or deteriorated seal can cause oil pressure issues that can be difficult to trouble shoot! Double check it before you throw it back on there!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 08-23-2010, 09:34 AM
Torque_SS's Avatar
Originally Posted by Matt@Texas-Speed
THIS!!
agreed check it if the retainer plate needs to be replaced do so its not that expensive and a pia once everything is on to go back into and yes use loctite on the bolts
Old 08-26-2010, 10:48 PM
slap(A)hoe's Avatar
seal r u meaning the gasket for the rear cover?? if so i bought a new one and i will locktite the bolts to thanks
Old 08-27-2010, 07:32 AM
vettenuts's Avatar
No, the cam retainer plate has a rubber seal molded into the metal. If that seal is bad your oil pressure will be low and can result in major problems.
Old 08-27-2010, 08:20 AM
1SLwLS1's Avatar
I would never re-use that part. Not that it can't be, but for $15, it is cheap piece of mind that if my oil pressure is crappy, I know its not that stupid gasket. When I was transferring parts to the 408, the old one only had about 5K miles on it from when I replaced it in the H/C swap. I went ahead and replaced it again. The gasket was flat and those bolts were previously torqued and not overtightened. Go ahead and get a new one.
Old 08-27-2010, 11:49 AM
MY99TAWS6's Avatar
Part number?
Old 08-27-2010, 12:48 PM
nysbadmk8's Avatar
For 9 dollars, replace the part.
Old 08-27-2010, 01:32 PM
vettenuts's Avatar
If you go new, the new part has countersunk screws, not hex head. You need new screws as well and the torque value is different. The one in my photo above is no longer made.
That is the reason I kept my old one after inspecting it. Some guys have found their plates with the countersunk holes (new design) cracked where the screws are. Some have found them cracked from the factory.
Old 08-27-2010, 01:58 PM
1SLwLS1's Avatar
P/N: 12556437
This is what the diagrams below show. I am not sure if GM gave the countersunk version a new P/N, I would think so, then the listed P/N may be unobtainable, and hopefully they would link to the new P/N.
The P/N for the std hex head bolts are P/N: 11515756. If the dealer was definitely on their game, they will list the new chamfered bolt P/N with all of this, I would like to this so. If you follow the link, #157 is the cam retainer plate and in it's description has the recommended bolts for that P/N. If you could find the new cam retainer plate P/N, you can enter it into the site below, and it's description should give you the corresponding bolt P/N.
I hope some of the adderall infested rambling was of some help.
http://www.compnine.com/largeimg/9705301F00-050.gif
Old 08-27-2010, 02:31 PM
vettenuts's Avatar
Here is the information I found when I bought the new plate. There was no listing of the new screws at that time. Link
Old 08-27-2010, 02:37 PM
1SLwLS1's Avatar
Hmm. That was back in 07' and I wonder which one I got whenever I ordered from TSP last October. Doesn't really matter, just more or less curious. HKE put the newest one on, so I am very confident they put the new bolts in. Just never noticed/payed attention to the countersunk plate.
Old 08-27-2010, 03:53 PM
blkbird's Avatar
Thats what happened to me. Check out the pics in the post.
https://ls1tech.com/forums/generatio...em-solved.html
Old 08-27-2010, 03:56 PM
ShortChevy's Avatar
Even still they sometimes stock that plate but never the bolts. My friend's was cracked when he did his cam install. Took about a week and a half to get new bolts. Dude seriously if your's in good shape run it. Bet if you went to the dealer and had work done they wouldn't replace that plate. LS1 gaskets aside from 97-98 water pump gaskets were designed to be reused. If it isn't torn and garbage, run it.
Quick Reply: can i reuse the cam retainer plate
