Anyone have dimensions of the stock clamshell mounts?
Old 08-23-2010, 06:03 AM
87SS's Avatar
Default Anyone have dimensions of the stock clamshell mounts?
I am currently installing an LS motor in my 87 Monte Carlo and have been messing around with my old Moroso solid mounts (frame and engine mounts). I am not really satisfied with the fit since one side will bolt up, but the other is off like ¼” (because of the LS adapter plate). Haven't spent much time in the garage lately, our new addition to the family has been keep us pretty busy with all the feedings and pooping/pissing
I have seen others have success with the original motor and frame mounts and thought about buying them since they are long gone off my car, but wanted to get some dimensions first before wasting even more $$$.
If anyone happens to have a stock clamshell, could you measure not only the width of the shell, but also the height from the center of the bolt hole to the top of the mount.
Thank you in advance for the help. Hopefully this will work out a little better.
