Oil Gallery Bearing/Ball
Old 08-23-2010, 07:19 PM
BLWNLT1_T/A's Avatar
Default Oil Gallery Bearing/Ball
It's been so long and I can remember where the damn bearing is supposed to be... I want to check to see if it is there before i button up things. Also is there an oil pan with a built in windage tray, or Should I use the stock one? If stock will work will installing be the same on spayed mains?
Attached Thumbnails Oil Gallery Bearing/Ball-photo0246.jpg   Oil Gallery Bearing/Ball-photo0247.jpg
Old 08-23-2010, 07:51 PM
WS Sick's Avatar
If you look there is a plug up top that covers the top side, the hile is under the rear cap. It should be in there not too far down.
When I get a block back from the Machine shop I allways drop a skinny long screwdriver in the hole to make sure the ball was there.
Old 08-23-2010, 07:57 PM
redbird93's Avatar
the balll bearing in the oil galley? you need to remove the last main cap and its in the whole that doesnt have a bolt or drive shaft in it. off top of my head
Old 08-23-2010, 08:02 PM
is there any way to see it from the top? I've got a long ex tenable led flash light (like the extend able magnets you see..)
Old 08-23-2010, 08:04 PM
WS Sick's Avatar
Yes remove that plug by the oil pressure sending unit and look down the hole , it should be about six inches down or so.
Old 08-23-2010, 09:39 PM
sweet thanks!!!
Old 08-23-2010, 10:27 PM
DAVE00's Avatar
The Canton pan has a built in windage and crank scraper. Good pan, but can leak around the drain plug sometimes on older pans.
Quick Reply: Oil Gallery Bearing/Ball
