Water pump block off?
Did a heater core delete, looped my hose outlet/inlet together. Recently discovered my PS pulley was rubbing through the hose. Now i really have to cap off my water pump somehow. Any ideas short of welding? Freeze plugs, vacuum caps... sizes? Any links? Help is appreciated! (and needed badly)
I just capped mine off with rubber caps for a while. Then last winter I took my water pump to a machine shop and had the barbs cut off and the holes threaded. Screwed the caps in and it's been sealed ever since.
hey i finally got it done man, took me a few days of searching to find those taps, finally found them at a little local hardware store and they weren't that cheap lol. Ended up working great. I threw some brass plugs in until my AN style plugs get here. I should start renting these taps out for 15 bucks...
