Cadillac CTS-V - Big Problem
View Full Version : Big Problem
Stone17
08-24-2010, 09:04 PM
I need some help.
Today when I was leaving work it was raining hard on the way home.
Top speed on the freeway was 40 -. About 30 min. driving slow my car (05 CTS-V) was shaking hard in 4th gear. I was thinking the rearend was letting go but I put the clutch in and the shaking went away. It did it 3 more time on the way home. I look under the car and every thing looks good and the car drives fine now.
wes8398
08-24-2010, 09:16 PM
If taking the clutch out eliminated the issue, then I would think it would involve your flywheel and/or associated parts. Are you sure it went away when you pressed the clutch pedal in?
Stone17
08-24-2010, 09:35 PM
I think so.
I could not hear any noise b/c of the rain. I could just feel it shaking from the rear.
wes8398
08-24-2010, 09:38 PM
You're sure it wasn't just a tire/wheel out of balance or something? The weights they use to balance a wheel can sometimes fall off. But if you're SURE that the shaking goes away when you depress the clutch pedal, than it's definitely something else.
Stepside
08-24-2010, 10:59 PM
Maybe something to do with anti-slip diff & traction control.
You did say it was raining hard.
mhhamrhead
08-25-2010, 05:01 PM
You said it was raining hard.
Any chance you could've been Hydroplaning and the Traction/Stability Control was kicking in? Maybe even some wheel hop if you were accelerating?
Kipper
08-25-2010, 06:28 PM
Rain plus your Corsa might be the problem, they arre really tight to the driveshaft. When I hit enough water, the exhaust would cool on one side and pull it over to where the driveshaft counterweight would bang into the pipes. I thought the whole car was coming apart. Slow down a few MPH or let off the gas and it was fine.
raven154
08-25-2010, 06:47 PM
I had some wheels and tires on my car that hated the rain. Not sure what the deal was but in heavy rain they would shake hard. I though my wheels were loose. Once it dried up, all the vibes when away. Strangest thing I have ever seen. I sold those wheels and tires lol
HPFreak
08-25-2010, 08:13 PM
Traction Control??
