Project "Homegrown" -65 Nova LS2 and KB s/c-
Old 08-25-2010, 07:41 AM
Grnova's Avatar
Default Project "Homegrown" -65 Nova LS2 and KB s/c-
Just started this build a few weeks ago It is my 65 Nova that had a B&M blown 383 that I am converting to a Lingenfelter LS2 w a Kenne bell 2.8l S/C. I am also putting a 4l80e with a Twist Machine padlde shifter car is set up for road and autocross. Here we are so far with the build. Just mocked up engine an built motor mounts and cross member. Now on to the front acc.brackets.
Old 08-25-2010, 09:07 AM
nastychevelle's Avatar
pics?
Old 08-25-2010, 10:49 AM
Grnova's Avatar
Before the tear down:
Here is the retired 383
then the new set up
new engine mounts and cross member
Old 08-25-2010, 10:04 PM
chevellepowered's Avatar
ok deff want more info on that intake that beast is sitting on.. self made ,, or where to get one?.. thanks..
Old 08-26-2010, 01:24 PM
Drewhelm's Avatar
Subscribing! Nice car! Can't wait to see the build.
I like how you did the driveshaft safety loop, think I will so something very similar!
Old 08-26-2010, 03:34 PM
z_speedfreak's Avatar
lookin good! those wheels & stance look bad *** too
Old 08-26-2010, 04:05 PM
Grnova's Avatar
Here is one of my favorite shots!
Old 08-28-2010, 05:37 PM
Grnova's Avatar
Many new parts arrived. Yesterday the Kwik brackets arrived.
So as I was installing the brackets they interfered with the Kenne bell bracket so I had to machine half of each down.
Then Today the 8 ribbed Sanden 508 A/C compressor arrived. Installed the Kwik A/C brackets and mounted it up.
Also had to run and get a tensioner and a puller from a 2002 z28.
Lastly made a idler pulley mount to attach to the S/C bracket.
Here is where I am at this time all pulleys mounted and a mock up of how the belt will be run. The roll of tape simulates the S/C pulley.
Now on to...
SUNDAY!!
Old 08-30-2010, 08:37 AM
bonecrrusher's Avatar
I go to the Carribean for a week and damn you move fast! LOL!
Pretty sure I commented on your engine setup over on Lateral-G.net....
Old 08-30-2010, 08:45 AM
Boosted One's Avatar
Looks great! Sharp looking Chevy II
Old 08-30-2010, 10:27 AM
digitalsolo's Avatar
Sharp car, nice build. Looking forward to updates.
Old 09-05-2010, 02:46 PM
Grnova's Avatar
Supercharger is all taped off and off to the powder coater.
Just got all the pulleys all aligned upgraded to 8 rib and the locking Katech adjuster mounted. Does anyone see and problems with this before I order the belt? Also who makes a good high output Alt for LS engines?
Old 09-05-2010, 03:09 PM
Clay_SS's Avatar
Very nice build! Cant wait to see it completed.
Old 09-06-2010, 08:32 AM
Looks great! very nice work. The only thing I would question is having enough wrap on the PS pump. You may want to stick an idler up between the water pump and PS pump to get more wrap around both the crank pulley and PS pump.
Frank
Old 09-06-2010, 08:58 AM
Bullitt4110's Avatar
Frank
If you look in post #8 it looks like the crank pulley has excellent wrap on it with his layout, the one thing stuck out to me was the long area between the tensionor and crank pulley without an idler or tensionor. What accessories are you running? If corvette ECS makes a really nice super strong tensionor that mounts right next to the crank pulley on the pass side.
Old 09-06-2010, 09:42 AM
Youre right! My bad, I was thinking the left side of the belt was going to wrap the water pump. You could do that then add the idler to the right and that would get rid of the long run, but I don't think the long run will cause you any problems. I'd leave istas is.
Old 09-08-2010, 10:15 PM
Grnova's Avatar
Default Too Green
As much as I hate to post this....
Here it is (going back Friday to be redone!)
Old 09-08-2010, 10:50 PM
Irish350's Avatar
idk what you're looking for as far as 'hi amp' alts go, but i got a massive one from excessive amperage, powdercoated black already. I run a decent sized system in my car and this is the backbone; might be overkill, but i figured Id throw it out there.
Lovin the progress
Old 09-09-2010, 05:40 AM
Are you concerned with the offset to the drivers side? Or the depth? It shouldn't matter if it is center or offset, it will be the same wrap either way.
Old 09-09-2010, 07:51 PM
John Deere called - even there green is a lighter shade! LOL!
Quick Reply: Project "Homegrown" -65 Nova LS2 and KB s/c-
