I come to the alter of LS engine guru's to get some question i have answered.....
Old 08-25-2010, 08:50 PM
JollyRoger44's Avatar
Arrow I come to the alter of LS engine guru's to get some question i have answered.....
Ok i have a 99 LM7 short block that i am going to have done over at the machine shop including boring it out to LS1 spec's. I am going to be reusing the stock 5.3 internals (crankshaft, rods). I will be ordering custom push rods once i get the block back and measure it out. I have listed some engine details below.
LM7 Block bored to LS1 spec's
LS6 cam
99 Port and polished 5.3 heads
Stock LS1 pistons
LS1 intake will be upgrading to LS6 intake when i can
LS7 lifters
stock injectors
I am not looking for big hp numbers, all i want to know if this setup will work together without eating itself.
Thank you LS engine gods... A men
I have searched and searched for answers but no real answers....
Old 08-25-2010, 08:56 PM
rtrygstad's Avatar
That is a really mild build. I wouldn't think you would have any problems.
Old 08-25-2010, 08:59 PM
Im doing a v8 240sx swap btw.
Old 08-25-2010, 11:06 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Have you weighed the costs of just picking up a block that is all ready to go vs. having machine work done to the LM7?
Old 08-26-2010, 06:49 AM
garygnu's Avatar
tr224 cam
Old 08-26-2010, 07:04 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by garygnu
tr224 cam
Sometimes your posts come across as if a robot was typing them.
Old 08-26-2010, 06:39 PM
Anybody else?
Old 08-26-2010, 09:04 PM
Anyone see any problems with my build?
Old 08-31-2010, 12:03 PM
Bump?
Old 08-31-2010, 12:10 PM
1SLwLS1's Avatar
Originally Posted by JollyRoger44
Bump?
Thats the only other logical choice.
Old 08-31-2010, 12:41 PM
Mkelcy's Avatar
No "problems" as such, with your build, but you might consider going with forged pistons on the stock rods/crank for an extra margin of safety if you later decide to push it.
Old 08-31-2010, 01:12 PM
I have decided. Im going to try and get a complete engine (there over priced here) and still build this one.
Old 08-31-2010, 02:47 PM
The_Rizzle's Avatar
you could just get a set of ls1 rods/pistons together, saves some work getting them installed. Low mileage sets on here go reasonably cheap.
With the extra compression of the 5.3 heads/ls1 bore you really should consider a slightly bigger cam. Theres aftermarket cams that let you use ls6 springs in the for sale section that should help wake up your build.
Old 08-31-2010, 05:31 PM
LilJayV10's Avatar
Schwanke engines, who is a sponsor, has a pretty good price on a 5.3 shortblock thats been bored to a 5.7. Just a thought.
Old 09-01-2010, 08:35 PM
I'll have it bored locally that way i can watch the build myself. Anyone else?
Old 10-07-2010, 12:53 PM
LS1TECH Sponsor
Schwanke Engines's Avatar
Looks like a good setup to me. Just make sure you get the LS6 cam installed around 112 on the intake. Should make great power and have a hint of chop in it.
Old 10-07-2010, 08:47 PM
garygnu's Avatar
must kill all humans.do not compute.
Old 10-07-2010, 09:01 PM
Arc00TA's Avatar
I would consider that the 240, being a light weight car, you may want to use an aluminum block to keep your weight distribution good. Otherwise looks like a solid build.
Old 10-09-2010, 06:51 PM
Sorry for the late bump but i want to either go to spray or F/I after awhile and i like the iron blocks better even though there heavy.
Old 10-12-2010, 08:10 PM
Bump... Has sat awhile and wondering if anyone has anything to add?
