guesstimates on hp with big cam
just saw this
http://www.carcraft.com/techarticles...ine/index.html
looks like i can expect around 430hp from just the cam swap
You will be in the 330-350 RWHP range the numbers in the article that you referred too are at the crank (flywheel) not the rear wheels there is a big difference in those two numbers ... when I said I made 411 HP I was referreing to rear wheel HP not flywheel HP...you will find that when people talk about horse power and torque being produced that they are referring to what is produced at the rear wheels.
