which pilot bearing for CTS-V T56?
Old 08-26-2010, 12:33 PM
vettedan's Avatar
Default which pilot bearing for CTS-V T56?
I’m installing a 2006 M12 T56 Cadillac CTS-V tranny on to a 1998 LS1 F-Body (originally automatic LS1).
Which pilot bearing should I use? I have the early Rifle (hollowed) style crank, so I need the larger style pilot bearing. I thinking I will need the 2006 6.0L pilot bearing that the caddy used pn-12557583. Can anyone help me with this dilemma?
Thanks,
Danny
Old 08-26-2010, 05:40 PM
85MikeTPI's Avatar
Large.
https://ls1tech.com/forums/manual-tr...-vs-small.html
Old 08-26-2010, 08:14 PM
vettedan's Avatar
Originally Posted by 85MikeTPI
Thanks,
I found out I'm going to need a slave spacer so i would need to use the duel friction clutch.
Danny
Old 08-26-2010, 08:52 PM
raven154's Avatar
Dual mass you mean? FWIW, with the LS7 clutch you can use an LS7 slave with no spacers or anything with the V trans. You can also run about any direct LS7 replacement with the LS7 slave with no other mods.
Old 08-26-2010, 11:50 PM
vettedan's Avatar
Correct Dual mass, So I can use LS7 slave/ LS2 flywheel & LS7 clutch and be ok?
Quick Reply: which pilot bearing for CTS-V T56?
