Pontiac GTO 2004-2006 - fat and skinnes
View Full Version : fat and skinnes
9sectruck
08-26-2010, 10:49 PM
can you get a 15 on the front of a 06 goat, if so what back spacing do i need for the front and rears, like to go to a full slick
wrp
08-26-2010, 11:04 PM
can you get a 15 on the front of a 06 goat, if so what back spacing do i need for the front and rears, like to go to a full slickI've run Holeshot 15 by 9.5 and 15 by 4 with 6 7/8 inch backspacing. You could call and ask what the backspacing they are using for the fronts. Those are 10 inch Hoosiers on the back and 185 by 65 by 15 Toyos on the front.
http://i512.photobucket.com/albums/t327/wrpnEthyl/Glamour%20Shots/SANY0006-1.jpg
nick.celis
08-27-2010, 02:59 PM
i have 15x3.5 1.75bs and 15x8 7.5bs
badpontiacs
08-28-2010, 12:04 AM
Rear: 15x10 7.5bs Weld WeldStar 26x10x15 Hoosier Slick
Front: 15x3.5 1.75bs Weld AlumaStar 2.0 185/65/15 Kumho PowerStar
All depends on the wheel. 15x8 should be a 5.5bs not a 7.5bs, its the same as an F-body.
6.0monsta
08-30-2010, 07:57 AM
This.
06 6.0 GTO
08-30-2010, 09:04 AM
I ran 2 spares in the front for a while at one time... seemed to do the trick.
gconnoyer
09-14-2010, 01:24 PM
15x8 5.5 BS
15x4 1.75 BS
http://i23.photobucket.com/albums/b388/gconnoyer/GTO/July%2018th/DSCN8395.jpg
Firebird67
09-14-2010, 03:49 PM
I see "Weld" or "clone" rims - What about lug nut spacing?
gconnoyer
09-14-2010, 04:20 PM
Weld and "clone" (from Jegs or summit or other lookalikes) are just not as light as real weld wheels.
for the lug spacing you want 5 x 4.75 (120.65mm)
9sectruck
09-14-2010, 09:14 PM
gto forum guys say you can only get away with 9inch on the rear, are you having any rub issues, especially on the launch, did you have to roll the outer fender lip up, any modding to the car at all to get the 10s to fit, if i can get a 10 thats def. what i want, thanks
gconnoyer
09-14-2010, 10:40 PM
I have Pedders 5/16 Drags Springs and BMR Drag Bags. Virgin Fenders.
The bags aren't necessary to keep the fenders off but I use them for tuning the launch.
Firebird67
09-15-2010, 11:25 AM
Thanks...
Jason's GTO
09-15-2010, 02:45 PM
HEy just a caution here the actual lug pattern on the GTO is 5x120 not 5x120.65 there is a diffrence. The GTO is Hubcentric which means the wheel ligne up on the hub not the lugs. Using the wrong lug pattern here can be an issue and break at the worst time. just a possibility and use caution.
gconnoyer
09-15-2010, 02:54 PM
Yea I know there is a difference, but anyone with a track set like this or anything almost always uses the 120.65 because almost no one makes a 120mm drag wheel.
I've never heard of anyone having problems doing this. From street wheels to a drag setup.
As long as you follow the proper bolting procedure when you put them on to get them centered its all good.
If you are going to get a drag setup though, You'll need to change out either the front or rear studs (can't remember). I changed all mine to ARP's (front and rear).
Jason's GTO
09-15-2010, 02:58 PM
Hey I hear ya, I'm just dropping a warning. Bogarts will set up a set of wheels buy the way but they are expencive.
gconnoyer
09-15-2010, 02:59 PM
hahaha yea anyone will make a properly machined wheel.
You just need to rob a bank is all lol
Jason's GTO
09-15-2010, 03:13 PM
agreed, or sell there first kid LOL!!
gconnoyer
09-15-2010, 08:14 PM
if only I had one.
I'd be down to sell a kidney though
badpontiacs
09-16-2010, 04:45 PM
BFH the inner wheel house, cut the shock dust tubes off, and cut or roll the outer fenders a bit. I also have drag bags and 0 rub issues!
stevieg
09-16-2010, 08:50 PM
i think the 05-06 brakes are to big, you may need to install 04 brakes they're a little smaller.
gconnoyer
09-16-2010, 09:18 PM
nope they fit over the big brakes just fine Steve
9sectruck
09-16-2010, 09:58 PM
what is the reason for changing the studs??
1SLOCV8Z
09-17-2010, 08:19 PM
i run extended studs for added safety.
heres some pics of mine 15x4 15x10
http://i412.photobucket.com/albums/pp210/busyduck/100_0564.jpg
http://i412.photobucket.com/albums/pp210/busyduck/100_0569.jpg
http://i412.photobucket.com/albums/pp210/busyduck/100_0567.jpg
TurboAv
09-18-2010, 09:12 PM
Greg Weld 15x3.5 front and 17x9.5 rear. Fits over the 05 brakes no problem.
http://i4.photobucket.com/albums/y121/jonschwenn/IMAG0008.jpg
c5formula
09-19-2010, 06:46 PM
so the skinnies off the front of an f-body will fit on our 05 gtos?
badpontiacs
10-12-2010, 11:50 AM
Yes. F bodies use a 1.75 bs on the front, along with the goats. The rears use a 7.5bs on a 10in wheel and 5.5bs on a 8in wheel.....same as an lt/ls f body. Hope this helps you a bit.
9sectruck
10-12-2010, 05:12 PM
ok im looking at the center line qualifier or the revs 15x10 rears, going to a full slick all time as my car is 100% weekend warrior/track, its only seen rain from inside the shop, so what is the right size tire for this set up with no cutting/beating on shit, thanks for all the input guys, looking to get in the 10s on 100stock long block no bolto on minus blower and a
tune
Commissar
10-13-2010, 11:34 PM
Greg Weld 15x3 and 15x 8, offsets as mentioned above. No grinding on required to make fit! Running MT ET Drag 26-10x15, now those require drag bags or spacers, they do stick out of the wheel well a bit. Well worth it at the drag strip though! Nothing like 6k+ launches!
http://i17.photobucket.com/albums/b53/Commissar04/Goat/IMG00242.jpg
http://i17.photobucket.com/albums/b53/Commissar04/Goat/IMG00243.jpg
http://i17.photobucket.com/albums/b53/Commissar04/Goat/IMG00244.jpg
twin turbo barge
10-16-2010, 04:54 AM
That is pretty sweet mate
NA$TY-TA
10-18-2010, 04:30 PM
That BOM is perdy.... makes me want a set. :) :devil:
Kyle
1SLOCV8Z
10-19-2010, 09:32 AM
thanks for the comments guys its my daily
