Need the size of the oil pan bolt used to drain oil. Mine snapped
Old 08-28-2010, 07:49 PM
CJDZ24_Z28's Avatar
Default Need the size of the oil pan bolt used to drain oil. Mine snapped
Yes my oil pan bolt snapped inside the oil pan when i was tightening the bolt after draining the old oil. I searched many times but cannot find the exact size of the bolt or thread pattern. Any help will be appreciated.
Old 08-28-2010, 08:55 PM
Squirts11's Avatar
Well, I don't have the exact size of the bolt, I usually call a dealership and they're able to give you the dimensions, pitch/thread/etc.
Old 08-28-2010, 09:09 PM
gofastwclass's Avatar
How do you snap a steel bolt that threads into aluminum...and were you able to get it out? Just curious.
Old 08-28-2010, 09:34 PM
CJDZ24_Z28's Avatar
I don't want to start the car up now due to the lack of oil to get it in my garage. Its to dark to work on it now. Tomorrow i'm getting an extrator or easy out and I'm going to try to drill it out. It wasn't an original GM bolt btw that snapped
Old 08-28-2010, 10:21 PM
King Nothing's Avatar
who put an aftermarket bolt in thats not the OEM one? btw good luck with gettin it out
Old 08-29-2010, 05:10 PM
CJDZ24_Z28's Avatar
Got it all taken care of fellas. Thanks to Pro Grab-it and my trusty drill! Btw the size of the oil drain plug is m12x1.75 got the replacement at Advance Auto Parts for $3.00
Quick Reply: Need the size of the oil pan bolt used to drain oil. Mine snapped
