10's? camonly, m6 on drs
Old 08-28-2010, 08:23 PM
studderin's Avatar
Default 10's? camonly, m6 on drs
one of my goals for this year has been to run some 10's in the everyday street setup. the stock z28 rims with drs on the back, no cutout fully exhust with the factory slp 20tl catback. puts down 425/393 thu the s60 with 4.30 gears, steel driveshaft, and flywheel. 28 m/t dr's on the back
on my car, cam only setup, been mid 10's race prep, my drag wheels, in good air. on the stock untoched 241s heads, fast92/92, american racing 1 7/8 headers, newera/fti streetsweeper cam, mike at newera tuned. it drives great, runs good. been getting closed running some low 11's for a while, think 11.22 was the best last year. can some some 11.teens this year, and last night even faster.
one 11.13, and a 11.07
but here is the best pass.
Old 08-28-2010, 09:00 PM
01SS99red's Avatar
Good numbers ,im still tying to get my car to hook on slicks and hit 10's.
Old 08-28-2010, 09:14 PM
nmass399's Avatar
your right there man, should not take much to get ya there.
Old 08-28-2010, 09:21 PM
I8AFORD's Avatar
That's sweet
he'll ya
Old 08-28-2010, 09:44 PM
SWEET98SS's Avatar
Thats awesome, hopefully raising my limiter and getting a 12 bolt with gears will get me close to 120 mph. Your car is flying.
Old 08-28-2010, 11:05 PM
studderin's Avatar
my shiftlite is 6400. went to 6600 and even 6800 and went slower.
i havnt had my car scaned at the track with hptuners to see were i really shift but the 1-2 id guess would be 6650 but the rest right arounnd 6500ish
Old 08-29-2010, 03:04 AM
Nitroused383's Avatar
You can do it! In my car I have my shift light set @ 6200 and my 1-2 shift ends up at 6800-7000 rpm. Shifting to 3rd is usually around 6600 and 4th is around 6200-6300 but I keep the light on for a bit to stretch 3rd gear out. This is logged with hptuners.
Old 08-29-2010, 05:23 AM
LS1ROPER's Avatar
So Close I like to see those #'s out of a M6
Old 08-29-2010, 07:23 AM
bad94sup's Avatar
Great numbers! Why not do a cutout or ewp to put you all the more closer?
Old 08-29-2010, 08:46 AM
Demonicbird00's Avatar
i think youll hit it def in sept/oct when the better air comes, but hell it could even come tomorrow
i take it you have 4.56?
any plans of coming to atco?
-brandon
Old 08-29-2010, 10:26 AM
DTB_LS1's Avatar
Awsome ET!!! You've really got your car dialed in. What settings do you start at for your 2-step and front/rear shock settings and how do the settings differ between running slicks vs drs?
Old 08-29-2010, 11:08 AM
flyinZ's Avatar
Did you modify that catback at all?
Old 08-29-2010, 11:17 AM
MATTREDSS's Avatar
Thats awesome! I think you will be able to def get your goal. Hopefully I can get mine in the 10s this year.
Old 08-29-2010, 11:26 AM
SMOKNSS's Avatar
Thats pretty impressive... what size tire is that (besides 28" tall).
Old 08-30-2010, 05:25 PM
studderin's Avatar
on the catback, all i got with the muffalr with the tips stuck, really stuck in. haha.theres a pic in my build thread. i didnt get the over the axle or ipipe with it. but did get a maganflow over the axle pipe. but thats made to go into the rear of a dual outlet on both sides. were the 20tl has both on one end, and the inlet is in the middle of the case. so i had to cut the over the axle pipe to change it a little, but its still 3inch up to the top of the rearend and into the muffalr, but i have a 4inch outlet ypipe i made, then to tappers after that. but testing some heads i ported the car was making 465-470whp. it was onlt 6-7whp peak running open 4inch ipipe on the side of the driveshaft. then it going thu the muffalr and into the tips. it was a lot quiter when i 1st got that muffler, after some dynos making that power. i noticed it really got louder, now afetr 2 years with the 2step and the backfires its not that quiet really like a dual/dual 20tl, lol
Old 08-30-2010, 06:24 PM
flyinZ's Avatar
Ah, i gotcha. I had thought about something along those lines, just wasnt sure if it was worth it or not. I know of one guy, that actually split the case of the muffler, replaced the pipe inside the muffler, w/ 3.5" tubing, then welded up the case back up. Not sure if it helped or not, but it supported a twin-turbo 355 LT1, a shade over 900rwhp..
Old 08-30-2010, 06:47 PM
studderin's Avatar
these tires are not 28, the list them at 27.7 but on these rims more like 27.5 or less. the\y would be better on a wider rim really. there 285 or 295/60/60 the m/h 275/60/16 fits these rims a lot better. these m/t are 7 pounds heavier each too. that pic is the m/and/h btw, i posted the m/t this spring in a thread about fitting 28 tires if you wnat to look for a pic, i know i did my my build thread too.
the car weight is 3360 with me, last year on these rims with the m/h drs. these rims are not light, there 20.9 per bare rim ,the heaviest 16 wheel i belive. the drag wheels are 70-80 pounds less.
Old 08-31-2010, 01:08 AM
nmass399's Avatar
What rpm are you launching the car at?
Old 08-31-2010, 06:18 AM
studderin's Avatar
6500 on the 2step
Old 09-01-2010, 10:33 PM
WSsick's Avatar
That is painfully close! Youll have it for sure man!
Quick Reply: 10's? camonly, m6 on drs
