Just a couple ?s on 91 s10 with ls1 swap
Ok im buying parts for the truck and what im wanting to know is on the transmission what are yall running? i want to run a th350 but what tailshaft is best? i know a longtail will fit perfectly on a fbody..but will it fit the same for a s10 ....... and what about the trans crossmember what are you guys doing for that?
can anyone tell me what exactly this is? 6010 - MSD Ignition Controller for GM EFI/Carbureted LS Engines is this all i need to start the truck up or what exactly do i need
Thats what i was thinking if a 700 can fit behind a fbody without any mods then the th350 longtail will work out great for it no problem........ looks like i have a bit more research to keep doing...... is there any special crossmember i have to use for the transmission to work?
depends on where you locate the motor in the engine bay. i made custom mounts so i didnt have to move the 700r4. i believe t5 trans crossmembers and auto crossmembers are located differently. if memory is correct, manual equipped trucks have the crossmember closer to the front, about 4" forward. really depends on where your mounts place the motor
