whats this wire? + funny idle
Old 08-29-2010, 12:04 PM
trilkb's Avatar
Default whats this wire? + funny idle
I have no clue if these 2 are related, im assuming not lol.
Anyways heres the wire/connector...
Also at idle the engine runs kinda rough, seems almost like its missfireing. and the volt gauge flutters quite a bit. Can this be only battery or alternator related? Was wondering if the optispark could play a role in this or not?
Old 08-29-2010, 12:56 PM
wllbndthrw's Avatar
The connector is to prime the fuel pump
Old 08-29-2010, 03:05 PM
trilkb's Avatar
ah thank you,
does it need to be hooked up or is it just to test it or something?
if it needs to be hooked up is it possible to get a picture of the connection? i dont see anything near it.
Old 08-29-2010, 03:12 PM
RamAir95TA's Avatar
That is the fuel pump prime connector. It's only for diagnostic purposes. Adding 12v to the connector runs the fuel pump.
Old 08-29-2010, 05:57 PM
95z28onjuice's Avatar
sweet
Old 08-29-2010, 07:43 PM
trilkb's Avatar
thanks, never knew that!
Old 08-29-2010, 07:46 PM
fex77k's Avatar
I've never had to use that. I usually just key the ignition.
Old 08-29-2010, 10:14 PM
TheTransporter69's Avatar
ha nice i just was looking at my car tonight and saw that and was wondering the same thing.
Old 08-29-2010, 11:36 PM
RamAir95TA's Avatar
When you key the ignition, the pump only runs for a few seconds then shuts off. This is useful if you wanted to continuously run the pump for any diagnostic purposes, or to even drain the tank.
Old 08-29-2010, 11:58 PM
fex77k's Avatar
Yea your right about that, I've never had to drain it thou.
Quick Reply: whats this wire? + funny idle
