Advanced Engineering Tech - Deleting ac airbox while keeping Heater assembly??
Oldsmobility85
08-29-2010, 07:11 PM
Anyone deleted there ac while still keeping the heater assembly on a 4th gen Fbody or maybe point me in the right direction?? Any help will be appreciated.
CJRiojas
08-29-2010, 09:34 PM
not the right forum. You might get better luck posting in another section.
MIGHTYMOUSE
10-11-2010, 08:26 AM
Look up what I did.
venom99
10-11-2010, 01:40 PM
you can delete it all the go buy a movea heater from jegs it weights a few pounds and is very small and compact
v7guy
10-26-2010, 02:35 AM
MIGHTYMOUSE is probably referring to this...
http://www.ls1tech.com/forums/drag-racing-tech/867874-light-weight-full-function-heater.html
the search is your friend.
Oldsmobility85
10-26-2010, 03:36 AM
Thanks for the help guys. I opted to keep my factory under dash unit and deleted the exterior part and then made my own plate out of sheet metal and covered it back up. and the best part is that I never once took the dash assembly apart or pulled the unit from the car.
