Anyone use ARP Ultra Torque Assembly Lubricant?
Old 08-29-2010, 07:31 PM
Rob94hawk's Avatar
Default Anyone use ARP Ultra Torque Assembly Lubricant?
Putting new heads on this week along with ARP head bolts and came accross this in the Summit online catalogue:
http://www.summitracing.com/parts/ARP-100-9909/
Old 08-29-2010, 07:35 PM
ThreeHonks's Avatar
I ordered it and will have it on tuesday to put my heads back on.
Old 08-29-2010, 08:07 PM
brucer's Avatar
most machine shops use oil when they torque main and rod bolts or studs,so i use oil.. my machine shop even specifies what weight oil they use, they put a card in the box with the parts, or they tag the block...
using different lubricants than what was initially used in the machining process can alter torque readings quite a bit..
Quick Reply: Anyone use ARP Ultra Torque Assembly Lubricant?
