Steam Tube Location
Old 08-29-2010, 10:03 PM
bpope's Avatar
Default Steam Tube Location
Hello,
I am trying to track down some overheating issues and I wanted to start with this. It might not make any difference...but I want to make sure the way I have this will work OK. I have the steam tubes circulating water back into the top of the waterpump and not back to the radiator as I have an aftermarket radiator.
Does this sound OK? I think it is circulating into the pump which ships it to the radiator...so i don't really think it matters if it plumbed directly in the radiator. Thanks for the help!
Old 08-30-2010, 07:02 AM
Pocket's Avatar
Thats not your issue. Swap cars have been drilling and tapping a port on the WP for years
Check the basics. Do you have atleast one small hole in your T-stat to prevent air lock. Is your air dam intact. Coolant level correct. etc
Old 08-30-2010, 08:32 AM
bpope's Avatar
Cool. I didn't think it would matter - but just wanted to make sure.
Yes, air dam on lower radiator support intact. Had a drilled 160° thermostat, took it out and put in a washer that had a 5/8" hole in in...helped a little...took it completely out and it didn't change it at all. Has aftermarket radiator and shrouded 16" puller fan.
I have done all of the basics...narrowed it down to the radiator being junk and clogged, Waterpump bad, or belt/tensioner setup is allowing it to slip.
It only heats up when it is driving...never tries to heat up at idle.
