Show me your cooling solutions!!!! Need some advice....
Well i got the car straightened out but im having cooling issues on these hot days.......yesterday it was 90 degrees out here and my temp crept up to about 235 on me.......not good. Of course I was asking for it.......the car is a built 385c.i. with 14:1 CR and big heads and a big SR cam with a big stall converter. Now heres the kicker the motor makes prob around 650hp....... and the car still has a stock radiator and stock fans in it......so theres the problem. What are you guys running for cooling systems (radiators/fans) on your high horsepower LT1's on the street??? I gotta get this solved cause other than this the car drives great!!
Help me out!!!
Thanks,
Mike V
Help me out!!!
Thanks,
Mike V
I see no reason why your stock setup should not work. I have 0 issues and never get over 190 and I have let it run for almost 2 hrs idling in 90 degree heat. re; I was running NMCA True Street and had a starter issue and as I sat there waiting to make the 2 back up runs I kept hearing everyone say he is going to overheat..blah,blah,blah. The only thing that got hot was my trans which pegged at 250 on the 3rd run
I have my front bumper support out and front end cut out which helps air flow, but most the radiator is blocked by Chrs1313 RA.
orig 95K mile radiator
OEM new water pump
Electric pump
160stat
We run LT1 radiators and stock fans in TT Lsx build making 1500HP and still no issues.
maybe flush the system?
maybe you have an airflow issues? is the lower plastic air damn still on?
OEM new water pump
Electric pump
160stat
OEM new water pump
Electric pump
160stat
OEM new water pump
Electric pump
160stat
I run an intake that blocks the radiator too. I don't have the bumper support or foglights either. Once the foglights are gone, the air is almost a straight shot to the radiator if you trim the inner bumper mount flap thing. If you are running a secondary trans cooler, try moving that off to the side of the radiator.
I would suggest getting some bigger fans (Spal with a homemade shroud) or (if you have a fan switch) leave the stock ones on all the time.
how are you guys opening up the front end? my fog lights died so im thinking about getting rid of them. but what else? pics would be nice.
And ive also read plenty about stock cooling systems keeping high HP cars cool. tuning helps too im sure HAHA.
A lot of the cars I've seen on here have removed the plastic shrouding to direct the air through the radiator too which will definatly hurt it, + an electric waterpump with a 3000+ rpm cruising speed isn't exactly ideal. Then throw in the trans cooler and intake that blocks off the radiator you're just asking for trouble. I'm running a becool on my car and it still sees 200 degrees around town in 100 degree days.
excuse the rough cut / test fitting and since has been cleaned up
here is my front end with the old over the radiator setup and now I have the Chrs1313 RA and Ls1 lid setup
The car never runs hot cruising or idling as I mentioned. The radiator gets a good amount of air with the bumper support gone and front nose cut open.
Forgive me for (maybe) being Capt. Obvious, but a PCM tune to turn ON the Low speed and Hi speed fans at their (respective) lowest temps in conjunction with the 160 degree thermostat helped me - but (as stated above), you probably already have that "tuned" in; however, I just switched (after flushing my cooling system twice) from Dexcool to 'standard' Prestone / Green radiator fluid antifreeze and my engine temps (which typically stayed between 175 and 185) dropped to between 165-170. A guy at a local radiator shop told me that was typical as Dexcool is a less efficient fluid for transferring heat vs. standard antifreeze. Just something to consider / try...
I've got the same front end setup Larry has (actually, he did the work on mine!) with the exception of a huge FMIC, and I'm not having any issues. Hasn't gotten hotter than about 190* sitting at idle. Making 648 RWHP on a procharger F1A, stock radiator, EWP, 160* thermostat, added water wetter to the coolant.
ok well the fog lights are gone as wells as the bumper support......as for the ram air thats not going anywhere i need that for the track also i did remove that little plastic piece in fron of the radiator so that could be hurting me......also yes lol the fans are adjusted correctly....i just plain out think that im trying to cool 700hp with a dam stock fan and radiator just aint gonna happen on a warm day. I called griffin he said hes got a radiator good for 700hp for $600 and i've already got a big fan off of a lincoln markVII so i think im gonna make a shroud and do it when i come back from the ltxshootout next week. Should solve the issues. Thanks for the help everybody.........i was basically just asking what you guys put in for radiators in fans for more cooling power.
