Advanced Engineering Tech - Crankshaft end play?
View Full Version : Crankshaft end play?
Oldsmobility85
08-31-2010, 08:56 AM
I have a 406ci sbc I am assembling and I am wondering what kind of crankshaft end play I should shoot for. Right now I have .0035 or 3.5 thousandths. It is a factory 400 block with clevite H bearings and a eagle 4340 forged crankshaft.
melsie68
10-08-2010, 09:55 PM
That is on the tight side. I usually shoot for .007-8". You will need to take out the thrust bearing (rear main bearing) and take material off of it until you reach the desired clearance.
ChucksZ06
10-09-2010, 10:27 AM
I think you are fine at that. It will loosen up some after you use it and will be just right.
