C5 detail
C5 detail
Started on this one around 10am and finished around 6:30.
A few spots were a little more stubborn than others and had to use a few different combinations.
Washed with Meguiars soap.
Spot clayed using clay magic.
Hood and decklid called for 3M Perfect it II/ LCC yellow pad then followed up with M105/M205.
The rest was corrected with Meguiars M105 / LCC orange pad.
Followed by Meguiars M205 / LCC black pad.
Polished with SFX polish / LCC blue pad.
Sealed with SFX blazin maize / LCC blue pad.
Tires and trim dressed with SFX dressing.
Fender wells cleaned with APC then dressed with Meguiars natural finish.
Glass cleaned with Stoners crystal clear / microfiber.
Brake dusted wheel
Dirty wheel well
Taped off
Swirls
Passenger door swirls
Hood swirls
Headlight swirls
Hood swirls natural light
Wheel clean
Wheel well cleaned up
Hood glazed reflection
Corrected front fender
Corrected rear passenger fender
Headlight corrected
Hood corrected
Decklid corrected
Hood corrected
Questions/comments are welcome.
Brake dusted wheel
Dirty wheel well
Taped off
Swirls
Hood swirls
Headlight swirls
Wheel clean
Headlight corrected
Hood corrected
Decklid corrected
Hood corrected
i was thinking of trying the surf city garage stuff on my sti, i use their car wash and like it. i need to take this clear bra off the front first makes the car look like it has a huge scratch on the front with the wax build up.
Tape it off. I've done a few vettes and lexus' that have had them installed and just tape off the 'seam' a little further than they actually are and you'll be good to go.
the build up is already there, i bought it used about a month ago with the bra installed. the problem lies with the wax, dirt, and debris are in the seam and the adhesive has started to seep out at the seam and is holding it all there. so i was going to remove it and completely detail the car since its cooling off outside.
