is it worth it to swap the bbk for a fast 102 for my set up
Old 08-31-2010, 01:30 PM
droptopT/A's Avatar
Default is it worth it to swap the bbk for a fast 102 for my set up
ok guys is it worth the money to swap out my bbk intake and tb for a fast 102/102 my curent mods are slpcai,mti lid,slp maf,bbk intake,bbk,tb,pacesetter lts,offroad y and a cut out with a ls6 cam and a slp pulley it put down 361 rwhp with a tune and ran 7.7 in the 1/8 when the car was auto with a vig 36-3800 stall
and now the car has a t56 swap and the new mods that are about to get installed are
lg 228/232
tsp 2.5 5.3 heads
ls2 chain
tsp ported oil pump
trickflow pushrods
ls7 lifters
please comment
Old 09-01-2010, 12:02 PM
Red99TA's Avatar
Current setup - no, H/C setup - yes.
Old 09-01-2010, 04:58 PM
LilJayV10's Avatar
I agree not with it. There's a thread on here where a guy put a fast 102 on his cam/bolt on car and didn't pick up anything from a ls6 intake. 7.7 is pretty damn good for what you have done to your car
Old 09-01-2010, 07:28 PM
zracer323's Avatar
It depends on how much $/hp you are willing to spend. with H/C you will most likely pick up some ponies. You will also lose about 10-12 lbs of the nose!
Old 09-01-2010, 08:16 PM
Andy819's Avatar
Im kinda in the same boat. But sorry to sound like a noob but what does H/C Stand for?
Old 09-01-2010, 08:47 PM
kinglt-1's Avatar
heads/cam
Old 09-01-2010, 08:59 PM
droptopT/A's Avatar
good info keep it coming
Old 09-01-2010, 10:04 PM
garygnu's Avatar
$1400 for 10-15 hp gain.
Old 09-01-2010, 11:52 PM
hitmanws6's Avatar
will it gain yes, will it be worth it? debatable. you will absolutely see gains across the entire rpm range. you could sell your BBK to offset some of the cost of the FAST
Old 09-02-2010, 12:05 AM
LilJayV10's Avatar
https://ls1tech.com/forums/dynamomet...sapointed.html
Old 09-02-2010, 12:08 AM
Element's Avatar
Could pick up a used Fast 90/90 combo, should still give a decent bump in power for a lot less than a brand-new 102 combo, especially if you sell the intake you have now.
Old 09-02-2010, 06:38 AM
SweetS10V8's Avatar
You gain across the board with the FAST intake thats for sure. Most likely in the 10-15hp range. People who are dissapointed with the cathedral port version just have bad data. I havent ever been dissapaointed with a FAST intake and Ive installed and tested a lot of them.
My stock LQ9, with all of its 190s duration, .469" lift, stock exhaust manifolds and all picked up 21rwhp with a FAST intake. So it doesnt require heads and cam, itll make more sure, but doesnt require it.
Old 09-03-2010, 03:14 AM
firebird99's Avatar
If you shop you can pick up a 90mm fopr a decent price i got mine here on the board for 600
Old 09-03-2010, 12:33 PM
fatmat80's Avatar
i too have never seen a fast not make good gains..idk
firebird99 your sig is funny..fucked up situation but funny..
