How do you get the balancer hub bolt out without an impact gun?
Old 09-02-2010, 01:15 PM
Rob94hawk's Avatar
Default How do you get the balancer hub bolt out without an impact gun?
Kind of hard to get this balancer hub bolt out without spinning the crank and with no impact gun. Ideas? Thanx
Old 09-02-2010, 01:22 PM
AChotrod's Avatar
I put the 2 bolts back in the hub use a bar between them and a breaker bar with a deep socket. Should only be about 75ft pds tq on it.
Old 09-02-2010, 01:26 PM
Rob94hawk's Avatar
much appreciated
Old 09-02-2010, 01:41 PM
RamAir95TA's Avatar
Yep, just wedge something between the ears of the hub. I used a long extension.
Old 09-02-2010, 01:44 PM
AChotrod's Avatar
If you have a couple old head bolts they work great in the hub and you wont damage the threads on your balancer bolts
Old 09-02-2010, 01:45 PM
Jcl_96TA's Avatar
I put a breaker bar on there a bfh it a couple times with the belt still on. Works every time..
Old 09-02-2010, 01:48 PM
fleetmgr's Avatar
You can also put a breaker bar on it, rest the other end of the bar on the ground and bump the starter.
Old 09-02-2010, 01:59 PM
Jcl_96TA's Avatar
Make sure you unplug the opti harness or something so the car wont start if you try that. Should work unless the bar slips off the ground and goes flying through your engine compartment..
Old 09-02-2010, 02:50 PM
Rob94hawk's Avatar
The engine is out and on an engine stand.
Old 09-02-2010, 06:22 PM
aboatguy's Avatar
Being on the stand makes it simple... use an adjustable wrench on one of the ears...
to keep the crank from spinning
I'll post a pic later
Old 09-02-2010, 06:26 PM
AChotrod's Avatar
Might work but I would never try that.
Old 09-02-2010, 07:22 PM
Rockstar
Johnny-LT1-runner's Avatar
The breaker bar and BFH are a proven winning combo.
Old 09-02-2010, 07:28 PM
brucer's Avatar
still have the flexplate/flywheel on it? use a flexplate/flywheel tool thats what they are for...
if flexplate /flywheel isnt mounted use a couple of long bolts in the flexplate/flywheel mounting holes and a large screwdriver or breakerbar/cheater pipe between the bolts and use the engine stand for the stop..
Old 09-02-2010, 07:52 PM
basketcase97's Avatar
X2 on this way
Old 09-02-2010, 08:00 PM
1994 TA's Avatar
If it is an M6 car put it in 6th gear. It it is an auto, leave the belt on and loosen a little and then remove th pully.
Quick Reply: How do you get the balancer hub bolt out without an impact gun?
