Help with VATS bypass, Houston area (Galleria)
Old 09-02-2010, 03:54 PM
FlyinlowZ28's Avatar
Default Help with VATS bypass, Houston area (Galleria)
Hey guys,
Thinking about doing the VATS bypass and wanted to make sure its done right, such as soldering the resistors instead of taping. If anyone wouldn't mind helping me out, that would be awesome. Going to get the resistors and ohm reader today. I've ohmed out the key but want to also ohm check the wiring harness. I recently had my ign lock cylinder replaced and am thinking maybe they didnt correctly match the cylinder and key, because twice since then it has failed to start (could that even be a possibility?) Anyways, thanks for any help. Im willing to drive to someones place to do this. Thanks.
