weird signal light blinker problem
Old 09-02-2010, 11:49 PM
ryanosborne's Avatar
Default weird signal light blinker problem
when i flick on my blinker it doesnt blink, it just stays lit up brighter than normal, but if i turn on my hazard lights they blink fine. last week only one of them did it. now the other side is doing it sometimes
Old 09-03-2010, 12:30 AM
67goatman455's Avatar
walk around the car with your hazards on, each blinker on, and just your tail lights on.
see if all the bulbs are working properly. i had a similar issue that all i had to do was clean the sockets, and put new bulbs in. eventually it did it again, and the remedy was to replace one of the tail light sockets
Old 09-03-2010, 12:55 AM
Sabaktes's Avatar
^^what he said
One of your bulbs is out.
Old 09-03-2010, 07:33 AM
tubbymcnugget's Avatar
do you have recessed water in your tail lights after rain? i know both of my t/a's had problems with recessed water build up in the tails after it rained, which eventually led to my tail light shorting out, which was no biggie, went to the junkyard, got a new socket and wired it up, then sealed my housing up tight and it works great now! it seems to be a common problem from what ive seen, so just check it out.
Old 09-03-2010, 12:04 PM
RamAir95TA's Avatar
More than likely it's one of the bulbs. Simple as that.
Old 09-03-2010, 12:10 PM
Village Troll
SS RRR's Avatar
Yep. Bulb out. IIRC blinkers and hazards don't run on the same circuit and have separate relays.
Old 09-03-2010, 03:12 PM
all the bulbs work, and the blinkers works sometimes?
Old 09-03-2010, 03:24 PM
TABBED 5.3's Avatar
there is a fuse (one of the larger metal ones) behind the radio area of the dash on the driver side. you should be able to get it at any of the parts stores. i had the same issue you are in that the lights all work, they just dont blink. replace that fuse and you should be good to go.
Quick Reply: weird signal light blinker problem
