Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Engine Guides
- Camaro and Firebird How to Install Mechanical Oil Pressure Gauge<br>Step by step instructions for do-it-yourself repairs.
mech. oil pressure gauge
so i want to install a mechanical oil pressure gauge in my lt1 car.. i wanna put it on the pillar.. i have never installed one before though i know it cant be that hard.. just need some tips on routing the oil line to the pillar.. also is there a gauge that most people usse? any gauges to stay away from? i def. dont want a leak springing in my car..
There's nothing wrong with a mechanical gauge, if you do run one, just be sure to run the line away from heat sharp edges, and where it can get pinched. A good trick to use is get the same amount of 1/4" vaccum hose and run it over the nylon line, this makes it more resestant to heat and sharp edges.
Village Troll
http://www.glowshiftdirect.com/
i refined my search techniques and found it.. thanks guys i have never looked into gauges before.. i wanna run a bigger than stock gauge in a single pillar pod just so i can have an exact reading in my face so to speak.. i dont wanna rely on the warning lights most times its too late when it comes on..
Whats all this talk about nylon line? That stuffs garbage. Use the copper tubing instead. I have a mechanical oil pressure gauge in my car (hvac panel) I see no issues doing this fuel I can see, but I feel a oil pressure gauge is safe to run inside the car. and I like having a mechanical gauge I dunno why just do. Anyways if you do go mechanical use the copper tubing instead of nylon, plus nylon tubing isn't allowed @ the track (NHRA Rules) Although I'm sure most tech guys won't look at that.
