Which throttle body can I use for my intake?
Hi All.
I have an Lq4 setup with L92 heads. I am in the market of shopping for the intake manifold, throttle body and mass air flow. Trying to keep the budget down.
I will be purchase a LS3 intake or L76 intake.
Is there different between the 2?
Which one is less trouble for installation?
As for the throttle body, How big of mm can I go with the LS3 and L76?
I want to used cable, not wires. and it seem everyone that sell the cable want too much.
Will I be able to use the 3 bolts throttle body from ls1 and buy a spacer plate for the 4 bolts? Have anyone done this setup?
http://cgi.ebay.com/ebaymotors/LS2-L...#ht_1927wt_939
Will the throttle body be too small?
Mass air flow, Can I used the stock ls1?
thank you
thank you
they seem to be the same,get the one you can buy the cheapest.opening size is 90mm,you could carefully dremel it out to 92 mm.I don't recall seeing a 3 bolt to 4 bolt spacer.I feel a stock 75 mm TB would be too small for your power potential,get a cabled 92 mm TB from TSP.get a custom cam for those heads ,you could make 500rwhp +.
