Almost got a 9sec Pass
Old 09-05-2010, 10:21 AM
HSESWS6's Avatar
Default Almost got a 9sec Pass
So I went to Cordova (9/3/2010) for the Friday Night TnT and Midnight Mayhem to test out the nitrous system (Zex Perimeter Plate / NX Lightning Solenoids) with the FJO progressive controller. Weather was good after the wind died down, DA was 2000' on first pass and 1000' on third.
Probably had the fastest car at Mayhem but took second in the shootout since I forgot to turn on the N2O and short shifted 3rd gear since the previous run it was slick down track and I got loose in 3rd. Oh well it was still a great night of racing.
First Pass - 150 Motor HP Jets (62/33) FJO 30-100% 1.0s
60 - 1.392
330 - 4.261
660 - 6.603 / 105.31
1000 - 8.568
1320 - 10.216 / 135.13
Second Pass - 150 Motor HP Jets (62/33) FJO 30-100% 0.7s
60 - 1.431
330 - 4.187
660 - 6.459 / 108.84
1000 - 8.382
1320 - 10.015 / 136.17
Third Pass - 150 Motor HP Jets (62/33) FJO 35-100% 0.7s
60 - 1.320
330 - 4.125
660 - 6.434 / 106.87
1000 - 8.378
1320 - 10.007 / 137.29
Forth Pass - 150 Motor HP Jets (62/33) FJO 32-100% 0.5s
60 - 1.357
330 - 4.125
1000 - 8.388
1320 - 10.011 / 138.27
Fifth Pass - 150 Motor HP Jets (62/33) FJO 40-100% 0.5s
60 - 1.318
330 - 4.113
660 - 6.544 / 99.06 (Slick down track - peddled 3rd)
1000 - 8.648
1320 - 10.351 / 133.62
http://www.youtube.com/watch?v=twDytooHs54
http://www.youtube.com/watch?v=dMJHfj-9FQ4
Old 09-05-2010, 10:57 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
MN6 guy eh..... Nice rowing there, that's pretty hard!
Old 09-05-2010, 01:19 PM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
Nice shift work, single digits can't be far.....
Old 09-05-2010, 03:39 PM
I8AFORD's Avatar
Nice wish I had ur 60ft
Old 09-05-2010, 04:09 PM
HSESWS6's Avatar
Thanks guys, yep still a T56 with all of the forward gears and its not pro cut or face-plated. First gear goes by really fast on the spray.
Old 09-05-2010, 04:24 PM
I8AFORD's Avatar
4.56 too much gear. On nos?
Old 09-05-2010, 05:22 PM
INTENESS's Avatar
Great driving man car leaves strong,U leaving on the 2-step?
Old 09-05-2010, 06:03 PM
HSESWS6's Avatar
On motor I had plenty of room with 4.56's trapped at 6900 on the spray its close trapping at 7300.
Yep leaving off the 2-Step that night it was set at 6600
Old 09-05-2010, 09:27 PM
billyflantos's Avatar
congrats
Old 09-05-2010, 09:57 PM
Carter01's Avatar
very impressive, I think the 9 is going to take a 6.3 in the 1/8 and you are not far off.
Great Job!
Old 09-05-2010, 11:06 PM
MYSTIC-1SC's Avatar
congrats on the times.. 9s are right there man.
Old 09-05-2010, 11:07 PM
Jonnie Bravo's Avatar
wow man you're knocking on the door and when things cool down a bit more and conditions improve hello 9's.
Old 09-06-2010, 08:46 PM
studderin's Avatar
very nice man, good to see some guys out going fast. and not going to a auto, thats for girls.
wait 1st i thought this was laura, but maybe not. i htink i meet you at the shootout if it is. ashlys ta is white, and michells is/was green.
Old 09-07-2010, 01:26 AM
BottleFedZ346's Avatar
Wow car launches HARD!
Old 09-07-2010, 02:45 PM
TAGOES11S's Avatar
One of the best launches and lowest 60fts I've seen with a m6. Mind sharing more specifics of Clutch/Suspension?
Do you have a diagram on how you wired the 2-step/controller up? Im in the process of wiring up a controller as well, I want to make sure it doesn't activate while on the two step.
Old 09-07-2010, 05:46 PM
HSESWS6's Avatar
I had the 2-Step Set for 6600 and leave with a fast clutch lift
The clutch is a spec 3+ with a billet flywheel, GM slave and the Tick Adjustable Master Cylinder
Front suspension is stock except for QA1R's (set on 4) and Strange Race Brakes, MT Front Runners
Rear Suspension is a MWC 9", MWC TA (Top Hole in Front), MWC LCA's (2nd Hole From Bottom? Might be 3rd), MWC PHR, QA1's (L6/R10 - I need a drag bar), Strange Race Brakes, 28x10.5x15 MT ET Drag
I attached a diagram of how I hooked up my FJO Controller and the Lingenfelter 2-Step For the 2-Step I rewired the clutch switch per their instructions for a +12V activation to the 2-Step. I then hooked that up to the FJO second input configured for +12V and it disables the N2O stage(s).
Old 09-07-2010, 05:52 PM
HSESWS6's Avatar
Thanks, still trying to go fast on a T56, all my friends want me to put a 400 in it and I almost did last year when I miss shifted 3-2 twice and bent valves each time.
Nope don't think we've met, my name is Greg and I wasn't at last years shootout, should be at this years though.
Old 09-08-2010, 09:17 AM
TAGOES11S's Avatar
Thanks Greg, Good luck at the quest for 9's! Might have to meet you over at US41 sometime. I have 2 other budy's with low 10 sec T56 cars as well. Could be a fun gathering.
Old 09-11-2010, 05:37 PM
WS6SP33D's Avatar
Nice launch and good shifts congrats
Old 09-11-2010, 06:30 PM
Head Hunter's Avatar
Sick 60' time - so close to hitting single digits, you're almost there
Quick Reply: Almost got a 9sec Pass
