Bolt-on's - which one next?
Old 09-05-2010, 12:15 PM
yabadaba's Avatar
Default Bolt-on's - which one next?
Guys, pretty much as soon as I bought my 2001 Z28 I fitted a SLP lid and GMMG catback and then did nothing more for a couple of years until a few weeks ago when I had LT's fitted and then a dyno tune done.
I'm now thinking that I should look at some of the other bolt-on's but am not sure which ones are considered most worthwhile doing. I was thinking maybe a ported throttle body. Would that be next on your list and, if so, would it make sense to do smooth bellows too?
Old 09-05-2010, 12:53 PM
SHovV's Avatar
P/P throttle body, smooth bellows and a LS6 intake would get you a pretty decent gain in power
Old 09-05-2010, 12:56 PM
The Mighty Texan's Avatar
What were the results of the dyno?
Old 09-05-2010, 12:59 PM
yabadaba's Avatar
Thanks for the reply. Already got the LS6 intake as that came already fitted as standard on my '01. Looks like the throttle body and bellows would make sense then and not too expensive either.
Old 09-05-2010, 01:00 PM
KevinR's Avatar
A converter is the best bang for your buck IMO
Old 09-05-2010, 01:06 PM
yabadaba's Avatar
At the wheels figures were 369.4 hp and 389.5 Ft Lb torque. The pre-tune figures were both about 20 less. That was on a Dyno Dynamics dyno. Before the LT's it made 299 rwhp (different dyno unfortunately).
Old 09-05-2010, 01:08 PM
ULTIMATEORANGESS's Avatar
TC for sure.
Old 09-05-2010, 01:10 PM
yabadaba's Avatar
Yeah, I've heard that said a lot before, but have always been concerned about how it would affect driveability and (to a lesser extent) mileage - my car's a daily driver.
Old 09-05-2010, 01:20 PM
KevinR's Avatar
It won't affect your drivability as long as you don't go too drastic. Get you one around 3500 and you won't regret it. It will make the car a lot more fun to drive. As far as gas mileage, you probably won't even see a difference.
Old 09-05-2010, 01:25 PM
99SSJarhead's Avatar
As good as a converter is, for the cost you could just finish out the engine bay bolt ons and still retain a stock like ride. That and unless he has an idea of the route he ultimately wants to go, the last thing he'd want is a converter at one stall just to find out that he purchased one to high/low for his needs.
So I'd say p&p the throttle body and possible the MAF ends, a smooth bellows is fine as long as you do the $4 home depot mod but not necessary, and an under drive pulley with new belts. That would more or less finish out your engine bay bolt on wise until you decide to do heads/cam and possibly upgrade to a better intake.
Old 09-05-2010, 01:50 PM
01SS99red's Avatar
With a U/D,p&p t/b,and smooth bellow would be decent gain.
Old 09-05-2010, 02:10 PM
LT/LS Guy's Avatar
Your next mod should be TC. P&P tb, ud pulley , bellows and such won't equal the gains a quality torque converter will. Do that and then finish up the little nick nacks.
Old 09-05-2010, 02:29 PM
Restricted User
z99ls1's Avatar
Get the fast toys ram air kit. That will get you more air in for sure. It is an awesome kit.
http://www.pfyc.com/pc/FB3003/FBUNDE...?a_aid=froogle
Old 09-05-2010, 02:37 PM
Restricted User
z99ls1's Avatar
I think a stall would be a reallly good gain. I either want to get the circle D 2800 stall or the Circle D 3200, but I cant decide. I really don't want my tranny to get hot and I don't want it to go into limp mode lol
Old 09-05-2010, 02:50 PM
DoggyB22's Avatar
Yea def get a stall, UD pulley, ported TB, FAST intake....
Old 09-05-2010, 03:05 PM
camz28arro's Avatar
I would get a underdrive ($250 w/ belts), chrs1313 ram air ($200), smooth bellow from home depot($4) and a ported throttle body ($50). Should gain around 12-15rwhp.
If your more serious and planning on doing a converter, I would go with at least a yank ss3200 or you would be leaving a lot on the table. I only lost about 1mpg going from the stocker and after a day it's not even noticable, after a month it just seems normal as far as drivability.
Don't get a FAST intake yet or you won't see any gain and be out a grand. You would need good heads and a mild-big cam to take advantage of a FAST.
Old 09-06-2010, 10:40 AM
Mike Morris's Avatar
Converter!!!
I drive my car everywhere. Makes a HUGE difference.
Old 09-06-2010, 11:02 AM
rob69zombie's Avatar
I'm at the point where you are but I'm a M6 so the converter is out of the question. I'm getting gears next. I'd recommend 3.73's for you. My wife's Z28 A4 with 3.73's has great acceleration and still pulls 25mpg city, (she NEVER goes WOT). I'd say u/d pulley next after that with the FTRA. That's my plan so I just applied it to your car, lol.
Old 09-06-2010, 12:03 PM
yabadaba's Avatar
Well, I guess that would make sense for me as I have the 2.73 ratio gears. It's pretty good to be doing 80mph at just 2k rpm, but I'd sacrifice some of that for extra grunt lower down.
Old 09-06-2010, 01:21 PM
Seit's Avatar
ARH 1-3/4 LT's with catted-y, GMMG catback, Magnaflow 14419 bullet, SLP lid, UMI tubular weld-in SFC's, BMR strut tower brace.
Based on these mods that you have
You Have cooler & 160 ° stat?
You want Great acceleration and power on the streets and road?
3.73 Gear
Nitto 555r
SsrA or FTRA w/ filter k&n
Lca with relocat bracket
Tune
I have these 5 in my car, I felt a big difference
You want very good numbers on the track?
High Stall Converter
Cut-out
LCA with relocat bracket
Nitto 555r or m / t
