help engine guys....why so slow
My engine w/built a4 and 12/bolt moser 4.11's 26/35/315 micky dr's (new) went 11.71@ 115.5.....1.606 60 ft. went through traps @ 6500 rpm's 3rg gear.I was hoping for low low 11's are high 10's.
408IronBug... 408ci LS1 Shortblock - incl. Block prep, Eagle 4340 Crank,
Eagle H-Beam Rods, Diamond Pistons, ARP Main Studs,
Balanced & Blueprinted,
1 3,600.00 3,600.00T
CC-875-16 LS1 'R' Lifters. High performance Replacement. 1 200.00 200.00T
AFR-1510F LS1 205cc cnc afr's 1 2,150.00 2,150.00T
COM-H1504043S Cometic Head Gaskets 2 75.00 150.00T
SLP-55002 SLP Double Roller Adjustable Timing Chain & Ported Oil
Pump LS1/LS6 GenIII
1 300.00 300.00T
CORE LS1 Short Block and Heads - no valvespings -1 600.00 -600.00T
CC-13755-KIT LS1 1.75 Rocker Kit with 5/16 Guide Plates 1 430.00 430.00T
CC-54-000-11 Keith Craft Custom LS1 cam 1 340.00 340.00T
ARP-234-4110 ARP LS1 head studs 1 199.99 199.99T
CC-26-921K Comp Cams Valve Spring, Titanium Retainers, Keepers and
Spring Seats
1 500.00 500.00T
CC-7955-16 Push Rods - LS1 7.400 5/16 - Stock length 1 130.00 130.00T
FAST-303608 FAST 36lb./hr Fuel Injectors 1 339.95 339.95T
GM-12585671 front crank seal ls1 1 16.09 16.09T
BCA-57080 Bearing 1 18.79 18.79T
MeZ-WP319S WATER PUMP FOR LS-1 1 479.99 479.99T
shipping overnight freight for water pump 1 80.00 80.00
SLP-100221 SLP LS1 F-Body Underdrive Pulley 1 199.95 199.95T
NGK-4177 NGK 4177 SPARK PLUGS 8 1.75 14.00T
GAT-K060763 Gates Micro-V Belt 1 48.99 48.99T
GAT-K040378 Gates Micro-V Belt 1 19.48 19.48T
NFM-8460N Oil Seal 1 14.43 14.43T
EDE-5280 Edelbrock 93-02 F-Body Torque Arm
Pump LS1/LS6 GenIII
1 300.00 300.00T
Spring Seats
1 500.00 500.00T
