Arp head bolt snapped taking off the head
Just wanted to see how many others have had problem(s) with arp bolts?
We were very cautious with our head reinstallation process and ensured clean bolt holes with use of thread cleaners and a air compressor. Double checked by using paper towels to ensure they were dry and clean.
I wasn't about to make the mistake of rushing a process that requires perfection.
Only one bolt snapped trying to remove the heads. I did notice that the bottom set of bolts were more tough to remove (closest to the exhaust ports) on both sides.
I have a nitrous kit with a 75 shot, maybe that was too much for the bolts and needed to get a stud kit?
Thoughts? Thanks all!
Torqued per the specs shipped with the bolts along with the lube.
There really isn't much to installing something as simple as this. Make sure surfaces and bolt holes are clean and follow the 3 step torque guide. It was very simple as I remember it.
Torque wrench was a husky that I picked up from home depot about 3 years ago when I installed the arp bolts.
I don't think calibration was an issue since the wrench was brand new when i used it.
LSX Mechanic
That being said you were probably close. I've TQ'd head bolts up to 90 ft lbs before, so if you stayed around the 75 range like the instructions said I doubt you went over 90 lbs.
I've never had an ARP bolt snap, but nothing is perfect and no product on the planet is impervious to failing. Good luck with getting that bolt out.
Location: Your girl's back door giving her the long stroke while you're at work
I had a ARP head bolt strip when I was taking it out, the head of the bolt rounded off. All the bolts broke loose and came out without a problem except that one
