motor problem need advize?
Old 09-06-2010, 01:56 AM
El_TransAm98's Avatar
Default motor problem need advize?
I just over heated my ls1 engine n it turn off running..but I just started again n it just started a nock when giving gas to pedal..and my oil pressure drops from 40 to 0 and it's stays there with a very bad nock..so I decided to take block out n take a look wat I found out was a bearing from crank it's very worn out it's scratch very bad..but crank is okay.. I'll shake the conneting rod n it's sound it the same nock n it was loose so that was the problem so this means I spun the main bearing? I just need to replace the main bearings n the problem is fix right? Thanks in advance
Old 09-06-2010, 05:10 AM
HotSilverBird's Avatar
hell you say?
