Timing cover/ ATI damper install
Old 09-06-2010, 08:14 AM
dubrado's Avatar
Default Timing cover/ ATI damper install
Can I tighten the timing cover all the way down before putting the damper on or do I leave it loose.
Not sure if the camper will go through the cover right if the cover is torqued down first.
thanks,
Old 09-06-2010, 08:32 AM
BaddBird's Avatar
Leave the cover bolts loose then install the damper to square up the cover.
Old 09-06-2010, 08:45 AM
dubrado's Avatar
thanks, just wanted to check before I put on the rtv and torque down
Old 09-06-2010, 08:59 AM
99LSS1's Avatar
You should use a front cover alignment tool.. This will pretty much eliminate any chance of leaks!!!
