Conversions & Hybrids - LS1 cam kit
View Full Version : LS1 cam kit
Miguel 69Chevelle
09-06-2010, 11:43 AM
Wat cam should I go with?...can anyone help?......thanks
Clay_SS
09-06-2010, 02:19 PM
What are your goals with the car? a little bit more info would help answer your question.
Miguel 69Chevelle
09-06-2010, 03:41 PM
My goal is to have the car sounding good and loud but also fast....more of a street car then anything....the motor is not in the car yet but some people say its eazy to put in the cam when the motor is out...
Clay_SS
09-06-2010, 07:57 PM
Texas Speed MS4 makes some good power and sounds amazing. You could call them up and they'd help you pick a cam. bullet cams is another good place to call.
usmcz28
09-06-2010, 09:25 PM
This is like asking for shoes over the phone in an other language!
What tranny are you using, rear gear ratio, weight of the car, mods to the engine, compression ratio, heads, work done to the heads, valve springs in the heads, what are your expectations for the car. DO you want performance mild or wild? track car, street/strip, grocery getter.
Man there's a shit ton to consider than just saying hey recommend me a cam that may work in XXXXXX. Every cam is different in every set up, it's like comparing apples and elephants.
