Another what cam without flycutting?
I have a 99 camaro with stock bottom end, 3:23, cirlcle d 3a stall (3400ish), otc headers, cat, slp lm1 and supporting mods, except a fast or ls6 intake. still looking for one. Also I have brand new set of prc ls6 stage 2.5 sitting waiting to get put on. They are milled to 62cc. My questions are what cam can I fit without flycutting? Also it is almost all street so more power under the curve, more torque, and good drivability, does not matter on mpg. yada, yada, please chime in especially if you are runing the prcs. also what head gaskets to use? fel pro 1041? thanks in advance
So the question should not be " WHAT CAM WITHOUT FLYCUTTING " ..
Cam selection consist of what power level you want, what type of race you want, drivability you want ..
Don't listen to anyone reply """ get the cam XXX """ or """ I have XXXXX cam and it works great """
Since you have alot of variables ( milled heads .. gasket selection ) do a custom cam from P.G or any cam spec'ers including what is your goal and heads/gaskets you want
